1564
Beginner
how to AIR-CAP1702I-E-K9 Join Controller 2504?
Dear all,
Do you let me know step to configure controller 2504 with AIR-CAP1702I-E-K9 ?
on AP it show: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.s
Best Regards,
Rechard
9 REPLIES 9
Hall of Fame Community Legend
DHCP OPTION 43 for
Beginner
Dear Leo, Do you have
Dear Leo,
Do you have document how to configure controller 2504 with AP ?
Now i'm not clear how to join AP with controller ?
Best Regards,
Rechar
Cisco 2500 Series Wireless
Beginner
Dear Leo, i got some error on
Dear Leo,
i got some error on AP
*Mar  1 00:06:52.139: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.2.59, mask 255.255.255.0, hostname AP0e0.1dfc.b000
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (192.168.2.10)
I create DHCP on Cisco 3560 and connect to Cisco 2960 POE by Trunking.
and i connect from WCL to Cisco 2960
on Core-switch 3560:
interface Vlan10
 ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/11
 description Connect to SW-2960
 switchport trunk native vlan 10
 switchport mode trunk
 spanning-tree portfast
On C2960
 description Connect to AP
 switchport access vlan 10
 switchport mode access
interface FastEthernet0/5
 description Connect to WCL
now it cannot talk to from AP to WCL.
Post the configuration of the DHCP scope.  I want to see if you have DNS settings and DHCP Option 43 or not.
What is the IP address of the Management Interface?
Highlighted
Beginner
Dear Leo, ip dhcp excluded
Dear Leo,
ip dhcp excluded-address 192.168.2.1 192.168.2.20
ip dhcp pool vlan10
   network 192.168.2.0 255.255.255.0
   dns-server 192.168.2.10
   default-router 192.168.2.1
   option 43 ip 192.168.2.10
ip dhcp-server 192.168.2.1
on WCL.
Port 1
ip add 192.168.100.10
Port 3
Connect to Sw2960
ip add 192.168.2.10
This is incorrect.
This should be "option 43 hex f104C0A8020A".
And where is your DHCP option 60?
Beginner
Dear Leo, Let me try add
Dear Leo,
Let me try add command option 43 hex f104C0A8020A
and i don't have DHCP option 60, Do we need to use DHCP option 60 ? and where should we config on ?
Best Regards,
DHCP Option 60 is for VCI.
DHCP Option 60 is for VCI.  Read THIS.
Content for Community-Ad
August's Community Spotlight Awards
