09-05-2013 08:04 AM - edited 07-04-2021 12:46 AM
Hi Everyone,
Is there any command CLI that can tell me if users are getting IP from WLC or not?
Mahesh
Solved! Go to Solution.
09-05-2013 11:18 AM
Hi Mahesh,
Try using ‘show dhcp summary’
For more information check the below link,
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70wlan.html
09-05-2013 02:01 PM
Hi Mahesh,
Yes, this mean you have not configured your WLC to act as a DHCP server with pre-defined pools.
If clients getting IP address they should get it from an external dhcp server.
If you check the interface configuration you should see a DHCP server IP address configured. In CLI if you type "show interface detailed
Here is an example of such CLI output
(4402-3) >show interface detailed vlan130
Interface Name................................... vlan130
MAC Address...................................... 00:0b:85:43:d8:67
IP Address....................................... 192.168.130.33
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 192.168.130.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. 130
Quarantine-vlan.................................. 0
Active Physical Port............................. LAG (29)
Primary Physical Port............................ LAG (29)
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 192.168.130.1
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... No
Guest Interface.................................. No
L2 Multicast..................................... Enabled
Rasika
09-05-2013 11:18 AM
Hi Mahesh,
09-05-2013 01:44 PM
Hi Anas,
>show dhcp summary
No scopes defined
Does this mean that users are getting ip from the External dhcp device?
Mahesh
09-05-2013 02:01 PM
Hi Mahesh,
Rasika
09-05-2013 02:13 PM
Hi Rasika,
Thanks for the reply.
Mahesh
09-05-2013 02:26 PM
Thanks for rating useful responses...
09-05-2013 12:38 PM
show capwap client ip config
To display the capwap static IP configuration, use the show capwap client ip config command.
Syntax Description
This command has no arguments or keywords.
Defaults
None.
Examples
This example shows how to display the capwap static IP information:
> show capwap client config
LWAPP Static IP Configuration
Primary Controller 9.41.80.88
09-05-2013 01:45 PM
Hi Abhishek,
Show capwap command is not available
>show c?
cac call-control cdp certificate client
coredump country cpu custom-web
(Cisco Controller) >
Mahesh
