09-14-2012 01:51 AM - edited 07-03-2021 10:40 PM
HI
i have cisco wlc 2504 connected with cisco 3600 ap,now the customer required n bandwidth speed ,but in wlc am not able to enable n bandwidth for ssid.
in radio policy of ssid also n bandwitdh is not showing,only this bandwidth showing a/g,g,b/g, and all
Please help on this on urgent basis
Solved! Go to Solution.
09-14-2012 03:32 AM
Yes the data rate will not exceed 54Mbps when WEP or TKIP encryption is configured as unicast key. radio policy of ssid will not show N as a radio policy you need to enable it globaly. is your client N capable? you do not need to upgrade to get N speed on your network.
09-14-2012 04:53 AM
Here is a doc
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a0080a3443f.shtml
09-14-2012 02:24 AM
you need to go to wireless>802.11a/n>High Throughput (802.11n) and enable 11n mode. Also do this under radio 802.11b/g/n.
Bashirhow to enable 100mbps speed on cisco wlc 2504 with 3600 ap
09-14-2012 02:40 AM
WLAN must be open or with AES encryption to get 802.11n rates
09-14-2012 03:20 AM
i did both the things after that also am not able to do,
currently am having
(7.2.103.0) this version ios whether do i need to upgrade this tolatest one ?
Please help on urgent basis
Veeramani.G
09-14-2012 03:32 AM
09-14-2012 03:40 AM
ok let me upgrade ,i will get back to u
09-14-2012 04:51 AM
Just to add... Your client must support 802.11N. There is no need to upgrade your WLC because that version is capable of 802.11N standard. Like mentioned, this is what you need in order to see 144mbps on the 2.4ghz an up to 300mbps on the 5ghz.
Open or wpa2/aes
WMM enabled on the WLAN SSID
40 MHz channel width on the 5ghz DCA
09-14-2012 04:53 AM
Here is a doc
09-16-2012 07:35 AM
Hi issue now solved after upgrade and after changing country code
