Highlighted
How to identify WLC Last Reset Reason -8500
How to identify the last reset reason for the WLC. I believe the older version of the wlc is providing the last reset reason once we issue Show sysinfo command.
---------------Show sysinfo---------------
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.3.143.0
RTOS Version..................................... 8.3.143.0
Bootloader Version............................... 7.6.100.0
Emergency Image Version.......................... 7.6.100.0
OUI File Update Time............................. Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... WLC-Primary
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1615
Redundancy Mode.................................. SSO
IP Address....................................... 10.6.110.104
IPv6 Address..................................... ::
System Up Time................................... 0 days 6 hrs 26 mins 15 secs
System Timezone Location......................... (XX)
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... XX
Operating Environment............................ Commercial (10 to 35 C)
Internal Temp Alarm Limits....................... 10 to 38 C
Internal Temperature............................. +22 C
Fan Status....................................... OK
RAID Volume Status
Drive 0.......................................... Good
Drive 1.......................................... Good
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 14
Number of Active Clients......................... 2913
OUI Classification Failure Count................. 116
Burned-in MAC Address............................ F8:72:EA:XX:XX:XX
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 6000
System Nas-Id.................................... WLC-8500
WLC MIC Certificate Types........................ SHA1
Licensing Type................................... RTU
7 REPLIES 7
Highlighted
VIP Advisor
Re: How to identify WLC Last Reset Reason -8500
how about below command :
> show logging last-reset
BB
*** Rate All Helpful Responses ***
I checked this command as well but its not showing
Highlighted
Highlighted
Hi @Nishad Dadhaniya ,
Yes, with show sysinfo you can get the last reset reason.
Use command grep include "Last Reset" "show sysinfo". Below is the sample output.
(Cisco Controller) >grep include "Last Reset" "show sysinfo"
Press any key to continue..
Last Reset....................................... Software reset
There are 1 lines matching the pattern Last Reset
HTH,
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Highlighted
HI ,
I believe it should show in the show sysinfo output as i have posted complete output i can't see anywhere for the last reset reason.
can you confirm your wlc os Version, I doubt the grep command will provide the last reset reason as its not showing in complete output.
Highlighted
HI ,
Highlighted
Content for Community-Ad
August's Community Spotlight Awards
