How to overcome user interception while copying and pasting commands in Cisco IOS-XE ?
jegan_rajappa
Hello Folks,
I am trying to copy paste commands from notepad template to Cisco 9800 IOS-XE WLC, but device is looking for user interception by entering Y/N, is there any way to overcome ?
Commands from template
ap dot11 24ghz shutdown
ap dot11 5ghz shutdown
ap country US
Output of copy paste
lab21(config)#ap dot11 24ghz shutdown
Disabling the 802.11b network may strand mesh APs.
Are you sure you want to continue? (y/n)[y]: ap dot11 5ghz shutdown
lab21(config))#
johnd2310
Level 8
Level 8
You will always have issues with cut and paste on the controller cli.  If you have Cisco Prime, you can try using it to push the commands you would like to apply.
John
**Please rate posts you find helpful**
