Stupid question, I need to reinstall MSE one the 3355 Appliance because the whole installation is screwed up. I downloaded the files from Cisco for the CISCO-MSE-L-K9-8-0-150-0-64bit.bin.tar.gz but how to do put this into a bootable format? the file is over 5GB so it doesn't fit into a DVD and I can't find a way to make a bootable USB from this.
Any help is appreciated.
