01-03-2019 08:14 AM - edited 07-05-2021 09:39 AM
Hi All,
Just wanted to know is there any way/ Process to stop capwap Discovery Process in Mobility Express.
Wanted to Run Every AP as ME in a single network single Switch, there is no Vlan in the Network.
This is for the testing purpose, to check if it works.
Rgds/SK
01-03-2019 12:39 PM
There is no way you can disable CAPWAP discovery process in a light weight AP. It is a survival mechanism built into LAP
Rasika
*** Pls rate all useful responses ***
01-08-2019 07:07 AM
Hi Rasika,
Thanks for your reply..
as per my knowledge , there was no process to disable but i was checking if someone has done.
i think its works in Wave1 AP in stand alone.
Rgds/Sudhir
01-08-2019 07:08 AM
01-08-2019 04:13 AM
You may however make all APs controller functionality capable so they can participate in the next master election in case of a failure.
Cheers!
