09-03-2018 04:20 AM - edited 07-05-2021 09:05 AM
Hi all experts, How can i upgrade only my Mobility Express Controller image ? I have only one AP which is ME Controller and it has running AIR-AP2800-K9-ME-8-5-120-0 currently but now i want to upgrade this ME Controller image to AIR-AP2800-K9-ME-8-5-131-0 but i'm unable to find any method for upgrading. I don't have any other APs to upgrade i just want to only upgrade my single AP which is ME Controller because this is my POC AP.
Reason for upgrading: Misbehaving, Can't show SSID sometimes and can't show connected clients on web interface therefore i need to upgrade.
Please suggest the method.
09-03-2018 04:22 AM
Here is the link to upgrade the sw on ME AP.
https://www.youtube.com/watch?v=X9GRWbsVAT4
Dont forget to rate helpful posts
09-03-2018 04:25 AM
I already watch this video and try that method also from cli but no luck because this method will work when we have sub-ordinate APs joined with controller so the controller will push image to all other APs but in my case i only have single AP which is already controller but i want to upgrade as i mentioned..
CLI Ref: transfer download
09-03-2018 04:39 AM
(Cisco Controller) >transfer download start
Mode............................................. TFTP
Data Type........................................ ap-image
TFTP Server IP................................... 192.168.200.200
TFTP Packet Timeout.............................. 6
TFTP Max Retries................................. 10
TFTP Path........................................ 8-5-131-0/
Do you want to Auto-Reboot after Complete? (y/N) y
Auto-Reboot check ENABLED!!
System will reboot within 5secs, ONLY upon Download COMPLETION to all Aps.
Configuration will be Saved before Auto-Reboot
DOWNLOAD may take some time......
Are you sure you want to start? (y/N) y
TFTP Code transfer starting.
No APs to upgrade.
Nothing to do for Image Upgrade.
the highlighted error i got when update from web interface or run the command transfer download start
09-03-2018 04:43 AM
If you follow the guide(above youtube video) then it will update the controller(ME AP) software.
09-03-2018 05:06 AM
yes i follow, but it is not updating. Please tell me is this required that other APs are joined on controller for upgrading or we can perform upgrade on single AP ?
09-03-2018 05:14 AM
We can update on single AP. I did in my lab and its working.
Dont forget to arte helpful posts
09-03-2018 05:20 AM
Alright thanks, but i don't know why this isn't working for me. We don't have any other method to upgrade ME image ?
09-03-2018 05:26 AM
you can also do it via CLI:
09-03-2018 05:49 AM
Thanks sandeep, don't know why this is annoying me. I tried both method
09-03-2018 06:15 AM
you can also try this method by using the command:
#archive download-sw /reload tftp://<tftp server ip address>/<filename.tar>
Rergards
Dontf orget to arte helpful posts
01-21-2021 02:06 AM
Hi Sandeep,
On what code did you recreate this ?
It does not work for me either if there is no ap connected to ME wlc ? verified on 8.5.135. code.
09-03-2018 05:33 AM
from the Cisco Mobility Express Deployment Guide the upgrade looks straighforward
maybe you are doing this with the wrong AP image? i mean, not the ME image but the lightweight-only image?
09-03-2018 05:50 AM
I procure ME image!
09-03-2018 05:53 AM
