How to Upgrade Cisco Mobility Express Controller Image
shehrozceh
Hi all experts, How can i upgrade only my Mobility Express Controller image ? I have only one AP which is ME Controller and it has running AIR-AP2800-K9-ME-8-5-120-0 currently but now i want to upgrade this ME Controller image to AIR-AP2800-K9-ME-8-5-131-0 but i'm unable to find any method for upgrading. I don't have any other APs to upgrade i just want to only upgrade my single AP which is ME Controller because this is my POC AP.
Reason for upgrading: Misbehaving, Can't show SSID sometimes and can't show connected clients on web interface therefore i need to upgrade.
Please suggest the method.
18 Replies 18
Sandeep Choudhary
Here is the link to upgrade the sw on ME AP.
https://www.youtube.com/watch?v=X9GRWbsVAT4
Dont forget to rate helpful posts
I already watch this video and try that method also from cli but no luck because this method will work when we have sub-ordinate APs joined with controller so the controller will push image to all other APs but in my case i only have single AP which is already controller but i want to upgrade as i mentioned..
CLI Ref: transfer download
(Cisco Controller) >transfer download start
Mode............................................. TFTP
Data Type........................................ ap-image
TFTP Server IP................................... 192.168.200.200
TFTP Packet Timeout.............................. 6
TFTP Max Retries................................. 10
TFTP Path........................................ 8-5-131-0/
Do you want to Auto-Reboot after Complete? (y/N) y
Auto-Reboot check ENABLED!!
System will reboot within 5secs, ONLY upon Download COMPLETION to all Aps.
Configuration will be Saved before Auto-Reboot
DOWNLOAD may take some time......
Are you sure you want to start? (y/N) y
TFTP Code transfer starting.
No APs to upgrade.
Nothing to do for Image Upgrade.
the highlighted error i got when update from web interface or run the command transfer download start
If you follow the guide(above youtube video) then it will update the controller(ME AP) software.
yes i follow, but it is not updating. Please tell me is this required that other APs are joined on controller for upgrading or we can perform upgrade on single AP ?
We can update on single AP.  I did in my lab and its working.
Dont forget to arte helpful posts
Alright thanks, but i don't know why this isn't working for me. We don't have any other method to upgrade ME image ?
you can also do it via CLI:
Updating Cisco Mobility Express Network using CLI
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-2/b_Mobility_Express_Deployment_guide/b_Mobility_Express_Deployment_guide_chapter_01000.html
Thanks sandeep, don't know why this is annoying me. I tried both method
you can also try this method by using the command:
#archive download-sw /reload tftp://<tftp server ip address>/<filename.tar>
more info: https://community.cisco.com/t5/wireless-mobility-blogs/ap-1832i-mobility-express-software-upgrade-from-8-2-to-8-5/ba-p/3384973
Rergards
Dontf orget to arte helpful posts
Hi Sandeep,
On what code did you recreate this ?
It does not work for me either if there is no ap connected to ME wlc ? verified on 8.5.135. code.
from the Cisco Mobility Express Deployment Guide the upgrade looks straighforward
maybe you are doing this with the wrong AP image? i mean, not the ME image but the lightweight-only image?
Step 1   Log in to the Mobility Express user interface and choose Management > Software Update.
I procure ME image!
do you see the file being accessed in the tftp server logs?
