216
Beginner
HTTPS issue on Aironet 2702i in autonomous mode
Hi there,
Since a couple of months (no real need the first I've seen this issue), I've noticed I could not connect to my Aironet 2702i in HTTPS.
It either shows on Chrome the NET::ERR_CERT_AUTHORITY_INVALID error in a loop mode (I can't continue to the website as I always did, it just comes back to the same state) or displays that I can't get access to the webpage on IE or Edge.
As a workarround I re-activated http and I could manage to update it to version ap3g2-k9w7-xx.153-3.JJ1 but this didn't solve anything. It is probably due to an outdated cypher or protocol.
Does anybody has a solution for that ? An even better option for me would be to be able to import a certificate from my own internal CA, but I already know there is no option in web GUI.
In advance, many thanks for your help ! :-)
2 REPLIES 2
VIP Engager
Re: HTTPS issue on Aironet 2702i in autonomous mode
Don't use the webinterface :)
Never used it (before ME) and can't really help.
You can use to create a new certificate (make sure the clock is correct on the AP!!! use NTP):
crypto key generate rsa general-keys
Then reload the AP and I think it should use the new certificate (which is still invalid in the browser, as it's self-signed).
Highlighted
VIP Mentor
please also try
1. with other Browser (IE /FIrefox).
2. Reset Chrome/ Update to the newest version
Dont forget to rate helpful posts
Content for Community-Ad
July's Community Spotlight Awards
