65
I can not connect to the AP 1602i
I can not connect to the AP 1602i,
Already tried several times via console, but I can not connect, when I connect to a dhcp server he gets an IP, but I can not connect via http, ssh or telnet.
Already tested on various browsers and already gave several reset, I saw a document that after 5 minutes without dhcp he takes 10.0.0.1 but it did not work, I came to test an IP 172.xxx but also can not connect at all.
Everyone's tags (1)
4 REPLIES 4
VIP Mentor
I think its a Controller
I think its a Controller based AP.
Do you have access via console ?
When you set up the connection, use these settings:
Bits per sec    :  9600
Data bits       :     8
Parity          :  none
Stop bits       :     1
Flow control    :  none
Don't forget to rate helpful posts
Highlighted
Thanks for the help, but my
Thanks for the help, but my settings are exactly like that.
VIP Mentor
You can reset the AP via the mode button as well
1. Disconnect power (the power jack for external power or the Ethernet cable for in-line power) from the access point.
2. Press and hold the MODE button while you reconnect power to the access point.
3. Hold the MODE button until the Status LED turns amber (approximately 1 to 2 seconds), and release the button. All access point settings return to factory defaults.
https://popravak.wordpress.com/2014/08/26/resetting-cisco-capwaplwap-access-point-to-factory-defaults/
Already reseted several times
Already reseted several times, 15 times at least.
Content for Community-Ad
August's Community Spotlight Awards
