i can't connect 1252 over 54 mbps
samart_sri
i can't connect 1252 over 54 mbps i can connect @ 130 - 150 mbps
i use intel 5300 AGN chipset also i set security in 1252 in WEP or WPA i can connect it @ 54 mbps why ?
please tell me setting with 1252 or configuration thank
now i setting only bvi 1 and radio same 1242 only or i must enable something now i see mcs 15 power is enable yet
7 Replies 7
Leo Laohoo
Should be WPA2/AES.
Should be WPA2/AES.
Do you have both radios enabled?
Now i don't have radius i think i don't use wpa2/aes with my clients. Do you have another solution ? .you have enough  documentation relate with this case  or do not.
Thank you.
No, no no, not RADIUS.  It's RADIOS.    You either have to use WPA2/AES or open/no authentication.
Cisco 802.11n Design and Deployment Guidelines
http://www.cisco.com/en/US/solutions/collateral/ns340/ns394/ns348/ns767/white_paper_80211n_design_and_deployment_guidelines.html
I think WPA2/AES must use authentication with radius [internal or external] don't use passkey for access with SSID. i want to use only encryption key only for access 802.11n please tell me more solution. in case open / no authen think it not secure.
thank you for best support.
You can disable broadcast SSID and enable MAC ACL for open/no authentication.
There are alot of free RADIUS programs.  Among then is FreeRADIUS.
No no.... here are your options for 802.11n Speeds...
Option 1
WPA2/AES - PRESHARE KEY
Option 2
WPA2/AES - EAP (Radius)
Option 3
OPEN
Options 4
OPEN (Mac filter / Auth)
If you find this helpful, please rate the post. Leo, myself and others work hard to anwser questions here on the forum! Thanks!
