I can't see Cisco Air Provisoning SSID in Mobility Express
GaeMi
Hello.
I usally use only console to Cisco mobility express AP settings. So I don't know CiscoAirProvision.
But Today, My customer ask me that how to use Cisco Air Provision web configuration.
My customer can't not saw any default SSID(Cisco Air Provison).
I already updated Customer's APs from 8.5 to 8.10 and reset APs and delivery to customer. So My Customer's AP is not first boot.
I am suspicious that SSID is not occurring because it is not the first boot.
No matter how much I take out an AP and reset it, CiscoAirProvisioning does not appear.
Please advise to me.
Go for a stable version and then give a try: 8.10.130.0
https://software.cisco.com/download/home/286306794/type/286289839/release/8.10.130.0
Dont forget to rate helpful posts
9 Replies 9
GaeMi
Ah, I tried to reset ME AP&Controller many times..
I can see CiscoAirProvisioning. I can access SSID.
But I can't access https://192.168.1.2/ (default gateway) but I can ping 192.168.1.2..
Thank your advice.
But I failed to access CiscoAirProvision..
I tried access https://192.168.1.1 or http service and ping.
I can't access https, ping, http...
192.168.1.2 also can't https, http. (can ping)
can you try to access # mobilityexpress.cisco #
I already tried this. But I can't access.
I tried ME 1815, ME 1830 on firmware 8.10.112.0. I also failed.
I will try another firmware version.
After updating AP to 8.10.130.0 and resetting, CiscoAirProvision works.
It seems to be a firmware issue.
I know for the EWC which is similar to the ME, you need to have the ap connected to the network and also need to obtain a dhcp address first. The ap seems to look for this before you can access the wizard in the UI.
-Scott
It does not work even if the IP is assigned to the AP. (I used DHCP Server to allocate ip)
It works normally after firmware update.
