05-29-2020 10:24 PM - edited 07-05-2021 12:07 PM
Hello
I have controller moblity express 1815i
1) If i want to increase Bandwith for AP1815i Cisco , how I can do that?
2) does it make sense if i change pool address ip from VLAN 30 with 10.2.30.0/24 to VLAN1 with 192.168.0.0/24 , allows increase Bandwith ???
I wait answer for Two questions !!!
Thanks in advance
Solved! Go to Solution.
05-29-2020 10:59 PM
05-29-2020 10:59 PM
05-30-2020 12:14 AM
Ok thanks i try and i tell you if all is good
thanks in advance
