increase throughput
Dhikra Marghli
Level 5
Level 5
Hello
I have access point installed a solar panel  and is next to the GSM cellular network antenna   Telecom
SO   i have two problem !!
1)  i want to know if  solar panel  and GSM cellular network antenna are  two reasons for low throughput !!! ??
problem : low throughput !!!
2)  how i increase throughput  for this environment  !!!!  (  installed solar panel and near  GSM cellular network antenna ) !!!?
i wait a reply and solution for two  probelm !!
thanks in advance
5 Replies 5
Dhikra Marghli
Level 5
Level 5
i wait a reply for two problem !!!
1)  solar panel  and GSM cellular network antenna are  two reasons for low throughput !!!!!
2)  increase throughput  for this environment  !!!!
 -1) Have you proven item 1 or are you suspecting it ? -2) There can be many other reasons for low throughput viewed from the WiFi perspective only.
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
the access point has been installed in the solar panel. I believe in electric field
and also it is near access point we have a cellular GSM antenna.Also access point and the cellure antenna are the same crossed band .
then the throughput will be low from 13 MBits to 1 Mbits !!
So  what is solution that increase throughput  ??
what is the distance between AP and and  a cellular GSM antenna. !!!?? that allow no collision !!!
if the solar panel is a obstacle to decrease throughput   !!!
Can you show us a picture?
-Scott
You need to provide more info. Like show us a picture and tell us what equipment you have and code version, what throughput you are getting and what you are expecting.
-Scott
