05-09-2012 12:41 AM - edited 07-03-2021 10:08 PM
Hi Guys,
Good Day,
I have cisco 4402 Wireless LAN Controller with Cisco Access Point (AIR-LAP1252G-E-K9), everything is running smoothly.
How come i use my Access Points without Wireless LAN Controller, is there any possibility then which AP model would be suitable?
I hope senior will reply me.
Cheers ....
05-09-2012 04:08 AM
Are you saying that you don't want to use the wlc? You can always either have the ap in standalone or lightweight in which you need a wlc. You convert the APs by uploading the correct code.
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
05-09-2012 04:12 AM
Now I don't know why you wouldn't want to use a wlc if you have one.... Soooo much easier to manage:)
