Installing AP in office
Greg Maaaag
Hello!
We have cisco 1941 as router in office, it's dhcp server, it has only vlan 1 192.168.4.0/24
I've set up 1142 ap for wireless clients
How can i make it give clients ips from dhcp server from vlan 1 ?
3 Accepted Solutions
Scott Fella
When using wpa2 you need to use aes. If you use WPA them its TKIP.
-Scott
Scott Fella
Change it to this
encryption vlan 1 mode ciphers aes-ccm
-Scott
Scott Fella
The bvi will get an IP address on Vlan 1 and so will your clients. The config looks fine other than what I told you to change.
-Scott
11 Replies 11
Scott Fella
If your 1941 is the dhcp, just create an SSID and place it on Vlan 1. That should be it.
-Scott
Scott Fella
You should be able to follow this guide for reference
http://www.cisco.com/en/US/docs/wireless/access_point/1140/autonomous/getting_started/guide/ap1140aut_getstart.html
-Scott
i did this:
version 12.4
no service pad
service password-encryption
hostname 3floor
logging rate-limit console 9
enable secret *
no aaa new-model
ip domain name office
dot11 syslog
dot11 ssid b1
   vlan 1
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii *
username b1_adm privilege 15 secret *
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers tkip
broadcast-key vlan 1 change 30
ssid b1
antenna gain 0
channel least-congested 2427 2432 2437 2442 2447 2452 2457 2462
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address dhcp
no ip route-cache
ip http server
ip http authentication local
no ip http secure-server
snmp-server community mon_cacti RO
bridge 1 route ip
line con 0
line vty 0 4
logging synchronous
login local
end
i've tried to make it to use authentication with wpa 2 key
it it ok?
Scott Fella
-Scott
Scott Fella
Change it to this
-Scott
thank you, windows clients will authenticate without problems?
do i have to make configuration of gigabit ethernet, i couldn't get it why bvi 1 interface gets ip from dhcp but not gig 0
will this configuration provide ip to clients from 1941 dhcp server?
Hi Greg,
Please be aware that AP is not a router..It is a bridge and does not use ip address on Gig0. Any traffic the AP gets on the radio interface (dot0) and physical interface (Gig0) are bridged to the BVI interface and are send to the rest of the network. So only BVI interface will have ip address on an AP.
Yes with the above configuration your wireless clients should gert dhcp ip address from 1941 provided the AP and router can reach each other.
Hope this helps.
Najaf
Please rate when applicable or helpful !!!
Scott Fella
-Scott
thank you everyone!)
Thanks for supporting the rating system... if you ever decide to use the 5ghz radio,  in order to achive up to 300mbps, you need to use a channel width of 40mhz:
https://supportforums.cisco.com/thread/2033758
no ip address
no ip route-cache
ssid b1
antenna gain 0
no dfs band block
speed basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel width 40-above
channel dfs
station-role root
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
well...now it's in reset state:
floor#show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       192.168.4.243   YES DHCP   up                    up
Dot11Radio0                unassigned      YES NVRAM  reset                 down
Dot11Radio1                unassigned      YES NVRAM  administratively down down
GigabitEthernet0           unassigned      YES NVRAM  up                    up
