Integrating WLC + active directory
bibinsherief
   We are supposed to create 4 SSIDS for staff, student and admin. The users of the three SSIDs are supposed to be inegrated with active directory.We were able to run the above process successfully, but now the users in "student SSID" are able to login into "staff SSID". What is the procedure to prevent the above issue.
Surendra BG
are the staff anf students using the same authentication?? If so, change the auth on both and try to block things for Student VLAN by using ACLs and this may help you!!
Lemme know if this answered ur question and please dont forget to rate the usefull posts!!
Surendra
Surendra BG
