08-02-2018 11:42 PM - edited 07-05-2021 08:55 AM
Hi all,
i am detecting an issue with WLC 3504 version 8.5.135.
Users with iPhone7/8/10 are not able to connect. They join to the network, receive IP address but it seems they are isolated.
Same users connected on WLC5520 version 8.5.135 are able to navigate.
Any idea?
Marco
08-02-2018 11:49 PM
08-03-2018 12:03 AM
Hi masato,
Is wlan config same ? YES
What kind of security method do you use? MAC Filtering with ISE authentication (same problem happened with no security on WLAN)
Is WLC interface config trunk or no VLAN? Trunk
what port do you use on 3504? from 1 to 4
pls show associated client detail information. (in attachment)
08-03-2018 12:43 AM
Can you please explain further what you mean by "isolated"?
Is the behaviour the same if using non-Apple wireless clients?
08-03-2018 02:19 AM
Can you please explain further what you mean by "isolated"? They are not able to reach DNS or other IP address.
Is the behaviour the same if using non-Apple wireless clients? No, only iPhone 7/8/10. Samsung, other brand and also iphone 6 and older are connected without any problem.
08-03-2018 02:21 AM
08-03-2018 02:22 AM
@Leo Laohoo wrote:
What APs are you using? 2700/3700?
3500/3600/3700
08-03-2018 02:24 AM
08-03-2018 02:37 AM
@Leo Laohoo wrote:
Do you have Fast Transition enabled on the SSID?
No, Disabled.
