01-25-2019 12:18 PM - edited 07-05-2021 09:45 AM
Hello, everyone,
I have a problem with iPhone phones and Cisco WLC 3504 with 66xAP1852.
Unfortunately it is not possible to make phone calls via VOIP without problems.
But this is not Jabber.
I use 802.1x with user authentication.
Firmware: 8.5.140
Here's the thing:
The iPhone breaks off during the phone call, because every now and then the iPhone switches to mobile radio.
Bandwidth is 140mbit/s everywhere.
Illumination was measured with 58dbm.
In order to find out the cause of the error, I downloaded the App inetTools and noticed that every now and then an ICMP package gets lost.
Mostly when the AP change takes place.
Samsung A8, as well as Samsung A5 devices do not have these problems.
Can anyone help me here?
I added the sh run-config directly and the output from "debug client <Mac-addr>"
Best Regards from Germany
Patrick Ebert
01-28-2019 08:39 AM
01-28-2019 11:41 PM
@patoberli wrote:
Hallo Patrick
Before I have a long look at your configuration file, which SSID are we talking about?
Gruss
Patrick
Hello, we are talking about the SSID "VOMOB"(802.1x) and for test purposes SSID "iphone" via psk.
but I have the same problem with both.
Best regards
Patrick Ebert
01-28-2019 11:55 PM
01-28-2019 09:09 AM
On the iPhone do they have wifi-assist enabled? I have seen issues with this in the past, it is generally the default option on them. If it is enabled I would test with it disabled and see whether the situation improves.
If it does improve, it is not necessarily a solution as it may indicate there are issues with the quality/performance of the wireless.
01-28-2019 11:46 PM
Hello.
yes, we have already done that, it brought a significant improvement, but the abortions are still there.
01-29-2019 01:24 AM
If you disabled it and it improved things but did not completely resolve it you need to start looking at how that iPhone is seeing the wireless when the issue occurs.
If you have a specific area where the client will have this problem, take the iphone to this location and on the WLC issue "show client detail <mac address of client>"
You are looking at signal strength and SNR indicator. I can see that you have disabled the lower data rates which is normally best practice but has it been confirmed that that Iphone is happy with the current coverage to support this?
If you look at the log you attached a lot of the 5Ghz radios are reporting 8+ neighour APs at significantly higher RSSI than -67dbm, you are using 40Mhz wide channels as well. Have you confirmed that 40Mhz is actually offering any advantages over 20Mhz in the real world?
