I just set up a mobility express network in my home consisting of three 1815w APs.
Network works great, all laptops, macs, TVs, xbox, etc are seeing 400mb/s as expected...
HOWEVER...
The newer (X & Xr) iPhones in the home refuse to connect. They are running iOS 12, and say "unable to join network" or "wrong password" when trying to join. Sometimes they will join for a few seconds and then kick off. iPhone 7 has no problems connecting whatsoever.
Using WPA2 security.
I read somewhere about fast SSID switching being an issue, however I can't see that option in the ME GUI.
Please help!
Hi There,
You will need to do it in the CLI
config network fast-ssid-change { enable | disable}
Reference:
<<< Please help the community by marking useful posts helpful, or accept as a solution if it resolved your issue >>>
