Cisco announces new innovations in SD-WAN, ISRs, SD-WAN Services, and Catalyst 9000 Series switches
218
Highlighted
Beginner
IR800 Plateform - Radio Frequency Band Select (Manually)
Hello;
I was trying to lock the radio frequency on IR809 and IR829 Routers following the instructions given under Section "Radio Frequency Band Select " in following link : https://www.cisco.com/c/en/us/td/docs/routers/access/800/829/software/configuration/guide/b_IR800config/b_cellular.html#id_80940
I realized that the option of band-select is not available :
Testrouter829(config)#controller cellular 0
Testrouter829(config-controller)#lte modem ?
  dm-log         Modem DM logging configuration
  link-recovery  Cellular Link Recovery
  svb-log        Modem SVB logging configuration
is the option hidden by certain user privilege level or just not available ?
ios : Version 15.7(3)M1
Modem Firmware Version = SWI9X30C_02.20.03.00
Everyone's tags (1)
Blog-New Labels
