Popup Hotspot Using ISR 1000 with WiFi/LTE for Teleworkers and Micro Branchesr
Ask Me Anything – How to Enable Network Connectivity to Remote Workers
1071
Highlighted
Beginner
Is it possible to change 1130AP's hostname on the controller ?
Is it possible to change 1130AP's hostname, not via CLI or web interface of aironet 1130AP, but via the controller's web interface ?
Are there possibility to give any bad impact on the Aironet if I do this ?
best regards
4 REPLIES 4
Highlighted
Contributor
yes, you can do it from the WLC
Goto WIRELESS page in the AP, select the AP and the AP you want to change the name, change the name and click on APPLY
NikhiL
Highlighted
Beginner
Thank you for your information
If I change the hostname of 1130AG from the WLC, the new hostname will be set on 1130AG automtically?
best regards
Highlighted
Contributor
yes, it will
Highlighted
Enthusiast
Changing the hostname will cause momentary disconnects for the currently connected clients, just remember that when you are making the change.
Content for Community-Ad
Cisco COVID-19 Survey
