03-18-2012 05:27 AM - edited 07-03-2021 09:48 PM
Is it possible to change 1130AP's hostname, not via CLI or web interface of aironet 1130AP, but via the controller's web interface ?
Are there possibility to give any bad impact on the Aironet if I do this ?
best regards
03-18-2012 05:52 AM
yes, you can do it from the WLC
Goto WIRELESS page in the AP, select the AP and the AP you want to change the name, change the name and click on APPLY
NikhiL
03-18-2012 09:21 AM
Thank you for your information
If I change the hostname of 1130AG from the WLC, the new hostname will be set on 1130AG automtically?
best regards
03-18-2012 09:58 AM
yes, it will
03-18-2012 11:51 AM
Changing the hostname will cause momentary disconnects for the currently connected clients, just remember that when you are making the change.
