05-11-2020 11:28 AM - edited 07-05-2021 12:02 PM
I'm not very familiar with edge computing modules for ISR 4K, but is there a way to run a C9800-CL on it? I believe it works using a UCS-E module that runs an ESXi host, but what about this ENCS thing? Is it less overhead that VMWare hypervisor?
05-11-2020 11:32 AM - edited 05-11-2020 11:32 AM
This data sheet has some details
The Deployment Guide has details for those supported modes (KVM, ESXi) - the ENCS is a KVM host that also supports 9800-CL mode.
05-12-2020 01:58 PM
The Data Sheet mentions only Cisoc 5000 ENCS plattforms. Which ISR 4K module would be adequate?
05-12-2020 03:08 PM
No you cannot run C9800-CL on ISR. You can run it on the other platforms including the ENCS or VMWare/KVM + public cloud.
