05-13-2015 07:07 AM - edited 07-05-2021 03:13 AM
Hello, we have and Cisco WLC 2504 with several SSID for our network (802.11X authentication). We have also an Guest SSID with PSK.
My question is it possible to shape the traffic of that guest ssid, so the guest will not be able to use more than for example 5Mbit/s ?
Or if it is not is there any other way to restrict the traffic of the guests?
Solved! Go to Solution.
05-13-2015 08:04 AM
Not in the WLC. The 2504 does not support per user bandwidth contracts.
You could do something at L3 to rate limit there.
HTH,
Steve
05-13-2015 08:04 AM
HTH,
Steve
05-13-2015 01:04 PM
What is the bast place to do that? On the firewall ?
05-13-2015 01:16 PM
Best place to shape is closest to the source. If your FW is the gateway, then that would be the best place to shape. Reall depends on where you can shape and your comfort level to implement shaping.
-Scott
05-13-2015 03:11 PM
You can try using the QoS role to limit the bandwidth of guest clients:
Please check the below link for more information :
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70ccfg.html#wp1254605
