Highlighted
Beginner
Is there a way to see client roaming activity on a Cisco 2504 wireless LAN controller?
Does the Cisco WLC have sufficient logging to keep track of clients that do fast roaming (e.g. 802.11r, 802.11k, 802.11v, 802.11w) between access points on the same WLC? I want to see that clients are NOT simply repeating the entire re-auth process when they switch between different APs that are broadcasting the same SSID.
Everyone's tags (4)
4 REPLIES 4
Highlighted
VIP Rising star
Re: Is there a way to see client roaming activity on a Cisco 2504 wireless LAN controller?
As far as i know no for logging.
You could do some debugs to view the roam process, or over the air packet captures to verify that it is happening as you want
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Highlighted
Beginner
Thanks. What kind of debug commands would you recommend? Would I run the debug command from the WLC, or do I need to SSH directly into the access point?
Highlighted
VIP Mentor
Check this posts:
How to debug client roaming - the 'deep dive'
https://community.cisco.com/t5/wireless-mobility-documents/how-to-debug-client-roaming-the-deep-dive/ta-p/3137412
Dont forget to rate helpful posts
Highlighted
Beginner
As a starter you could just pick a particular client and use:
debug client <MAC_ADDRESS>
...at the WLC CLI.
You will see the authentication/roam process for that client only.
Content for Community-Ad
Cisco COVID-19 Survey
