11-25-2012 07:26 PM - edited 07-03-2021 11:06 PM
Hi there, I am trying to setup my lap with a new WLC 2100. but failed to connect to the WLC via second switch.
In WLC 2100, fa0/2 connect to the second switch, Fa0/1 connect to PC.
In second switch 3560, it's fa0/2 connect to the WLC as trunk port. port fa0/1 is in vlan 1
Management int ip in WLC is 192.168.1.1 in VLAN 1 assoicarted with port is fa0/1, the PC ip is 192.168.1.2.
When PC connect via fa0/1 in WLC, I can ping 192.168.1.1 from PC. but connect PC to fa0/1 in 3560, no reply.
To my understanding, fa0/2 in WLC is trunk port by default and the vlan1 is allowed, since fa0/2 in 3560 also configured trunk, there is no reason, why I can not ping the WLC. any suggestion ?
Solved! Go to Solution.
11-26-2012 05:16 PM
I guess you're thinking that physical port that is not configured will be trunk and will forward all the traffic, that is incorrect. you've to map interfaces to all the physical port that you're planning to use. WLC != switch.
11-25-2012 07:50 PM
Well the main thing is if your tagging the management interface or not. If you tag it with '0' then native vlan on the trunk port would be 1. If you set the tag as '1' then the WLC is actually tagging vlan 1 and might be the cause of your issue.
11-25-2012 07:53 PM
What Scott said ... See attached its set to 254 which means its TAGGING 254.. If its blank.. Then nothing is being tagged ..
BTW -- Happy Thanksgiving Scott !
__________________________________________________________________________________________
"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
11-25-2012 07:56 PM
Happy belated Thanksgiving to you to George.
11-25-2012 09:25 PM
Hi guys, I have tried to change the management Vlan to 0 in WLC and same issue persists? what is next step to check which issue could be? Thanks...
11-25-2012 09:57 PM
Roy
Lets get back to basics. Take the port going to the wlc and make it vlan 1 and not trunk. On the wlc make sure the vlan ID is blank not zero.
11-26-2012 10:59 AM
George, vlan id is an mandatory config on wlc to create an interface, it can't be blank is what i believe.
Roy,
WLC vlan 0 == untagged, anything other than 0 is tagged on WLC side. Port that is mapped with vlan id 0 only on WLC is an access port, it'll become trunk once an tagged vlan is mapped to that port with or without vlan id 0.
if you've vlan id set 0 on WLC then it communicates to an native/untagged vlan on switch side.
(Cisco didn't change this airespace style vlan stuff yet)
WLC Switch
vlanID 0 Native/Untagged vlan X
vlanID 5 Tagged vlan 5
does show arp switch on wlc and switch shows the arp learnings on each side, if not there could be vlan id issue between wlc and switch.
11-26-2012 11:06 AM
I stand corrected .. You are correct 0 is untagged .. Thanks for the correction .. +5
11-26-2012 11:43 AM
Thank you!!!
11-26-2012 02:27 PM
Hi Saravanan/George, thanks for this clearification.
WLC = Switch this make it much easy to understander the WLC.
OK, Further to Saravanan's comment, can I make following conclution:
all ports in WLC by default are trunk port.
port in WLC - if assicated with vlanID 0 - that port is access port and allow that native vlan only
Port in WLC - if assicated with valn ID other than 0. - port is trunk port, it will allow both that vlan and other vlan (include natvie vlan.)
based on above, the WLC port connecting to the second switch should be in default state (trunk port), and the port in second switch connect to this port should be configured as trunk port accordingly.
If mananagment Vlan is in VLAN ID0 and associated with WLC fa0/1, that fa0/1 should only used for connect to a PC for web access to the WLC.
if above statement is correct, I will try again in my lab as following:
On WLC (2100)
Interface VLAN IP add assoicated local port
managment interface Vlan id 0 192.168.1.1 fa0/1
AP management int Vlan id 0 192.168.1.2 fa0/2
trunk to the Swich trunk(default) n/a fa0/3
On Second Switch (3560)
trunk to the WLC trunk (dot1q) n/a fa0/3
Acces port to PC valn1 default 192.168.1.8 fa0/1
with this configuration in WLC and Swich, I should be able to ping the managment interface, AP managment interface from PC.
in addition to above, If I add dynamic interface in WLC for SSID with vlan 10, providing I have router connect to the 3560 switch with subinterafce setup, I should be able to ping valn 10 ip add from my PC as well? please let me know if you have any commnet, I will give a try in my lab and update you later.... once again thanks both for help....
11-26-2012 03:11 PM
Hi Guys,
I have just configure the WLC as above and the result is nagtive.
plug PC to Switch fa0/1 no reply
plug PC directly to the WLC fa0/1 no reply. (was replying first time when I configure the WLC)
seem to me there might be some error in the intial configuration in WLC, since the initial configure is very simple, I post it as following, please help to see if there is any error:
after reset to factory default in WLC 2100:
Would you like to terminate autoinstall? [yes]: yes
System Name [Cisco_32:18:a0] (31 characters max):
AUTO-INSTALL: process terminated -- no configuration loaded
Enter Administrative User Name (24 characters max): admin
Enter Administrative Password (3 to 24 characters): ********
Re-enter Administrative Password : ********
Management Interface IP Address: 192.168.1.1
Management Interface Netmask: 255.255.255.0
Management Interface Default Router: 192.168.1.25
Management Interface VLAN Identifier (0 = untagged): 0
Management Interface Port Num [1 to 8]: 1
Management Interface DHCP Server IP Address: 192.168.1.25
AP Manager Interface IP Address: 192.168.1.2
AP-Manager is on Management subnet, using same values
AP Manager Interface DHCP Server (192.168.1.25):
Virtual Gateway IP Address: 1.1.1.1
Mobility/RF Group Name: MRF-GP
Network Name (SSID): TEST
Configure DHCP Bridging Mode [yes][NO]: yes
Warning! Enabling Bridging mode will disable Internal DHCP server and DHCP Proxy feature.
May require DHCP helper functionality on external switches.
Allow Static IP Addresses [YES][no]: yes
Configure a RADIUS Server now? [YES][no]: no
Warning! The default WLAN security policy requires a RADIUS server.
Please see documentation for more details.
Enter Country Code list (enter 'help' for a list of countries) [US]: au
Enable 802.11b Network [YES][no]: yes
Enable 802.11a Network [YES][no]: yes
Enable 802.11g Network [YES][no]: yes
Enable Auto-RF [YES][no]: yes
Configure a NTP server now? [YES][no]: no
Configure the system time now? [YES][no]: no
Warning! No AP will come up unless the time is set.
Configuration correct? If yes, system will save it and reset. [yes][NO]:yes
show interface summary
Interface Name Port Vlan Id IP Address Type Ap Mgr Guest
ap-manager 1 untagged 192.168.1.2 Static Yes No
management 1 untagged 192.168.1.1 Static No No
virtual N/A N/A 1.1.1.1 Static No No
11-26-2012 04:24 PM
Hello Roy
Starting from the last configuration that you added:
Could you please let me know how is the switch-port configured for the WLC and the switchport going to the PC?
Also, what is the PC IP address?
Please notice that you can't configure the PC IP address of 192.168.1.2 as that IP is the one of the ap-manager interface.
Also, from the WLC CLI, please issue a:
- show port summary
I'll be waiting these outputs.
11-26-2012 05:05 PM
Hi Carlos thanks for the reply, please be adviced that I can ping the WLC management interface if I plug into WLC port fa0/1 now.
other comments please see bellow:
Also, from the WLC CLI, please issue a: - show port summary
STP Admin Physical Physical Link Link
Pr Type Stat Mode Mode Status Status Trap POE
1 Normal Disa Enable Auto Auto Down Enable N/A
2 Normal Disa Enable Auto Auto Down Enable N/A
3 Normal Forw Enable Auto 100 Full Up Enable N/A
4 Normal Disa Enable Auto Auto Down Enable N/A
5 Normal Disa Enable Auto Auto Down Enable N/A
6 Normal Disa Enable Auto Auto Down Enable N/A
7 Normal Disa Enable Auto Auto Down Enable Enable (Power Off)
8 Normal Disa Enable Auto Auto Down Enable Enable (Power Off)
11-26-2012 05:10 PM
Ok this is your problem:
The WLC 2106, 2112 or 2125 can only have one physical port connected to a switch.
On this case, if you take a look the management and ap-manager interface are currently mapped to port 1.
However "port 1" is disabled and you have port 3 connected and enabled, but you do not have any WLC interface mapped to port 3.
According to your current configuration, and according to the best practices, all the traffic of the WLC will go through port 1.
11-26-2012 05:16 PM
