join to ME 1815
Dhikra Marghli
Level 5
Level 5
Hello
i have a smple problem then i would some one help me to resolve because this is project urgent
AP1815 ( with 8.3.111) can ping Moblity Express 8.8.100 then i have router as a server DHCP :
1.1.1.0 /24 with ip address managment 1.1.1.21
i have some command in ME  :
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.02.05 13:42:09 =~=~=~=~=~=~=~=~=~=~=~=
show ap join stats summary all
Number of APs.............................................. 2
Base Mac AP EthernetMac AP Name IP Address Status
00:fc:ba:67:49:c0 N A AP28AC.9E89.48E0 1.1.1.23 Not Joined
a0:93:51:17:94:00 N A AP780C.F0DB.2A90 1.1.1.24 Not Joined
(Cisco Controller) >show ap summary
Number of APs.................................... 0
Global AP User Name.............................. AP-SOTETEL
Global AP Dot1x User Name........................ Not Configured
Global AP Dot1x EAP Method....................... EAP-FAST
* prefix indicates Cisco Internal AP
(Cisco Controller) >show ap join stats detailed
Incorrect input! Use 'show ap join stats detailed <ap-mac>'
(Cisco Controller) >show ap join stats detailed ?
<Cisco AP Mac> Enter MAC address of the specifc Cisco AP.
(Cisco Controller) >show ap join stats detailed 00:fc:ba:67:49:c0
Sync phase statistics
- Time at sync request received............................ Not applicable
- Time at sync completed................................... Not applicable
Discovery phase statistics
- Discovery requests received.............................. 66
- Successful discovery responses sent...................... 0
- Unsuccessful discovery request processing................ 66
- Reason for last unsuccessful discovery attempt........... Layer 3 discovery request not received on management VLAN
- Time at last successful discovery attempt................ Not applicable
- Time at last unsuccessful discovery attempt.............. Feb 04 01:43:17.019
Join phase statistics
- Join requests received................................... 0
- Successful join responses sent........................... 0
- Unsuccessful join request processing..................... 0
- Reason for last unsuccessful join attempt................ Not applicable
- Time at last successful join attempt..................... Not applicable
- Time at last unsuccessful join attempt................... Not applicable
Configuration phase statistics
--More-- or (q)uit
- Configuration requests received.......................... 0
- Successful configuration responses sent.................. 0
- Unsuccessful configuration request processing............ 0
- Reason for last unsuccessful configuration attempt....... Not applicable
- Time at last successful configuration attempt............ Not applicable
- Time at last unsuccessful configuration attempt.......... Not applicable
Last AP message decryption failure details
- Reason for last message decryption failure............... Not applicable
Last AP disconnect details
- Reason for last AP connection failure.................... Not applicable
- Last AP disconnect reason................................ Not applicable
Last join error summary
- Type of error that occurred last......................... Lwapp discovery request rejected
- Reason for error that occurred last...................... Layer 3 discovery request not received on management VLAN
- Time at which the last join error occurred............... Feb 04 01:43:17.019
Ethernet Mac : 00:00:00:00:00:00 Ip Address : 1.1.1.23
--More-- or (q)uit
(Cisco Controller) >?
apciscoshell Go to AP Console
clear Clear selected configuration elements.
config Configure switch options and settings.
cping Send capwap echo packets to a specified mobility peer IP address.
debug Manages system debug options.
eping Send Ethernet-over-IP echo packets to a specified mobility peer IP address.
grep Print lines matching a pattern.
help Help
linktest Perform a link test to a specified MAC address.
logout Exit this session. Any unsaved changes are lost.
mping Send Mobility echo packets to a specified mobility peer IP address.
ping Send ICMP echo packets to a specified IP address.
reset Reboot (hard reload) options.
restart Restart (soft reload) the switch.
save Save switch configurations.
show Display switch options and settings.
test Test trigger commands
transfer Transfer a file to or from the switch.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.02.05 13:59:42 =~=~=~=~=~=~=~=~=~=~=~=
show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.8.100.0
OUI File Last Update Time........................ N/A
System Name...................................... controlleur
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.2489
IP Address....................................... 1.1.1.21
Last Reset....................................... 0: unknown
System Up Time................................... 0 days 0 hrs 50 mins 52 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US - United States
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
--More-- or (q)uit
Number of Active Clients......................... 0
OUI Classification Failure Count................. 0
Memory Current Usage............................. 30
Memory Average Usage............................. 30
CPU Current Usage................................ 2
CPU Average Usage................................ 1
Flash Type....................................... Compact Flash Card
Flash Size....................................... 1073741824
Burned-in MAC Address............................ 78:0C:F0:DB:2A:80
Maximum number of APs supported.................. 50
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1/SHA2
(Cisco Controller) >show time
Time............................................. Mon Feb 4 02:00:54 2019
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
NTP Version.................................. 3
NTP Polling Interval......................... 86400
Index NTP Key Index NTP Server Status NTP Msg Auth Status
1 0 0.ciscome.pool.ntp.org Not Synched AUTH DISABLED
2 0 1.ciscome.pool.ntp.org Not Synched AUTH DISABLED
3 0 2.ciscome.pool.ntp.org Not Synched AUTH DISABLED
(Cisco Controller) >ping 1.1.1.23
Send count=3, Receive count=3 from 1.1.1.23
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.02.05 15:31:32 =~=~=~=~=~=~=~=~=~=~=~=
AP-SOTETEL
Password:**********
Warning: Missing TFTP/CCO params, Please Configure the Image Download Params
Welcome to the Cisco Mobility Express command line interface.
Only commands which are listed in the command reference guide for this release are supported.
http://www.cisco.com/c/en/us/support/wireless/mobility-express/products-command-reference-list.html
(Cisco Controller) >debug ca?
cac call-control capwap calea
(Cisco Controller) >debug capwap detail enable
(Cisco Controller) >*spamApTask0: Feb 05 16:39:26.420: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.24:5248
*spamApTask0: Feb 05 16:39:26.420: a0:93:51:17:94:00 packet received of length 258 from 1.1.1.24:5248
*spamApTask0: Feb 05 16:39:26.420: a0:93:51:17:94:00 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:39:26.420: a0:93:51:17:94:00 Discovery Request from 1.1.1.24:5248
*spamApTask0: Feb 05 16:39:26.420: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:39:26.420: a0:93:51:17:94:00 Total msgEleLen = 229
*spamApTask0: Feb 05 16:39:26.420: a0:93:51:17:94:00 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:39:26.420: a0:93:51:17:94:00 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:39:26.420: a0:93:51:17:94:00 Total msgEleLen = 152
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 Total msgEleLen = 108
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 Total msgEleLen = 103
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 Total msgEleLen = 98
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 45
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 Total msgEleLen = 78
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 28
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 Total msgEleLen = 58
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 Total msgEleLen = 49
*spamApTask0: Feb 05 16:39:26.421: a0:93:51:17:94:00 Total msgEleLen = 40
*spamApTask0: Feb 05 16:39:26.422: a0:93:51:17:94:00 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:39:26.422: a0:93:51:17:94:00 Vendor specific payload from AP A0:93:51:17:94:00 validated
*spamApTask0: Feb 05 16:39:26.422: a0:93:51:17:94:00 Total msgEleLen = 26
*spamApTask0: Feb 05 16:39:26.422: a0:93:51:17:94:00 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:39:26.422: a0:93:51:17:94:00 Total msgEleLen = 0
*spamApTask0: Feb 05 16:39:30.824: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:39:30.825: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:30.826: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:39:30.826: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:30.826: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:39:30.826: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:39:30.826: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:39:30.826: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:39:30.826: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:39:30.826: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:39:30.831: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:39:30.831: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:39:30.832: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:30.832: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:39:30.832: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:39:30.832: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:39:30.832: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:39:30.832: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:39:30.832: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:39:30.832: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:39:45.079: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:39:45.079: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:39:45.080: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:39:45.086: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:39:45.086: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:39:45.087: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:39:54.579: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:39:54.579: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:54.580: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:39:54.580: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:54.580: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:39:54.580: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:39:54.580: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:39:54.580: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:39:54.580: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:39:54.580: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:39:54.586: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:54.586: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:54.586: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:39:54.586: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:39:54.587: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:39:54.588: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:39:54.588: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:39:54.588: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:39:55.884: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.24:5248
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 packet received of length 258 from 1.1.1.24:5248
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 Discovery Request from 1.1.1.24:5248
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 Total msgEleLen = 229
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 Total msgEleLen = 152
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:39:55.884: a0:93:51:17:94:00 Total msgEleLen = 108
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 Total msgEleLen = 103
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 Total msgEleLen = 98
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 45
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 Total msgEleLen = 78
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 28
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 Total msgEleLen = 58
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 Total msgEleLen = 49
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 Total msgEleLen = 40
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:39:55.885: a0:93:51:17:94:00 Vendor specific payload from AP A0:93:51:17:94:00 validated
*spamApTask0: Feb 05 16:39:55.886: a0:93:51:17:94:00 Total msgEleLen = 26
*spamApTask0: Feb 05 16:39:55.886: a0:93:51:17:94:00 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:39:55.886: a0:93:51:17:94:00 Vendor specific payload from AP A0:93:51:17:94:00 validated
*spamApTask0: Feb 05 16:39:55.886: a0:93:51:17:94:00 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:04.083: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:04.083: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:04.083: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:04.083: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:04.083: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:04.084: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:04.085: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:04.085: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:04.099: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:04.099: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:04.100: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:04.101: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:04.101: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:04.101: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:04.101: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:13.588: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:13.588: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:13.589: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:13.595: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:13.595: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:13.596: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:13.597: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:13.597: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:13.597: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:13.597: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:13.597: 00:fc:ba:67:49:c0 Total msgEleLen = 0
(Cisco Controller) >de*spamApTask0: Feb 05 16:40:23.092: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:23.092: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:23.092: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:23.092: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:23.093: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:23.094: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:23.094: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:23.094: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:23.099: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:23.099: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:23.100: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:25.353: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.24:5248
*spamApTask0: Feb 05 16:40:25.353: a0:93:51:17:94:00 packet received of length 258 from 1.1.1.24:5248
*spamApTask0: Feb 05 16:40:25.353: a0:93:51:17:94:00 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:25.353: a0:93:51:17:94:00 Discovery Request from 1.1.1.24:5248
*spamApTask0: Feb 05 16:40:25.353: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:25.353: a0:93:51:17:94:00 Total msgEleLen = 229
*spamApTask0: Feb 05 16:40:25.353: a0:93:51:17:94:00 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:25.353: a0:93:51:17:94:00 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 Total msgEleLen = 152
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 Total msgEleLen = 108
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 Total msgEleLen = 103
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 Total msgEleLen = 98
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 45
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 Total msgEleLen = 78
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 28
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 msgEleLength = 5 msgEleType = 1048
b*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 Total msgEleLen = 40
ug *spamApTask0: Feb 05 16:40:25.354: a0:93:51:17:94:00 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:25.355: a0:93:51:17:94:00 Vendor specific payload from AP A0:93:51:17:94:00 validated
(Cisco Controller) debug>
(Cisco Controller) debug>*spamApTask0: Feb 05 16:40:25.355: a0:93:51:17:94:00 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:25.355: a0:93:51:17:94:00 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:25.355: a0:93:51:17:94:00 Total msgEleLen = 0
(Cisco Controller) debug>*spamApTask0: Feb 05 16:40:32.599: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:32.599: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:32.599: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:32.599: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:32.600: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:32.601: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:32.601: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:32.601: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:32.607: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:32.607: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:32.608: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:32.608: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:32.608: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:32.608: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:32.608: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:32.608: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:32.608: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:32.608: 00:fc:ba:67:49:c0 Total msgEleLen = 0
capwap errors enable
(Cisco Controller) debug>capwap errors enable
(Cisco Controller) debug>*spamApTask0: Feb 05 16:40:46.866: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:46.866: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:40:46.867: 00:fc:ba:67:49:c0 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.867: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.869: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:46.870: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:46.871: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:46.871: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:46.871: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:46.871: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:46.871: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:46.871: 00:fc:ba:67:49:c0 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:40:46.871: 00:fc:ba:67:49:c0 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:46.871: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:54.809: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.24:5248
*spamApTask0: Feb 05 16:40:54.809: a0:93:51:17:94:00 packet received of length 258 from 1.1.1.24:5248
*spamApTask0: Feb 05 16:40:54.809: a0:93:51:17:94:00 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:54.809: a0:93:51:17:94:00 Discovery Request from 1.1.1.24:5248
*spamApTask0: Feb 05 16:40:54.809: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:54.809: a0:93:51:17:94:00 Total msgEleLen = 229
*spamApTask0: Feb 05 16:40:54.809: a0:93:51:17:94:00 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 Total msgEleLen = 152
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 Total msgEleLen = 108
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 Total msgEleLen = 103
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 Total msgEleLen = 98
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 45
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 Total msgEleLen = 78
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 28
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:54.810: a0:93:51:17:94:00 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:54.811: a0:93:51:17:94:00 Vendor specific payload from AP A0:93:51:17:94:00 validated
*spamApTask0: Feb 05 16:40:54.811: a0:93:51:17:94:00 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:54.811: a0:93:51:17:94:00 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:54.811: a0:93:51:17:94:00 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:40:54.811: a0:93:51:17:94:00 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.24:5248
*spamApTask0: Feb 05 16:40:54.811: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.24:5248
*spamApTask0: Feb 05 16:40:56.362: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.362: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.362: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:56.362: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.362: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:56.363: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:56.364: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:56.364: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:56.364: 00:fc:ba:67:49:c0 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:40:56.364: 00:fc:ba:67:49:c0 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.364: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.368: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.368: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.368: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:40:56.368: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.368: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:40:56.368: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:40:56.369: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:40:56.370: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:40:56.370: 00:fc:ba:67:49:c0 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:40:56.370: 00:fc:ba:67:49:c0 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:40:56.370: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.863: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.863: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.863: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:41:05.863: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:41:05.864: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:41:05.865: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:41:05.865: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:41:05.865: 00:fc:ba:67:49:c0 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:41:05.865: 00:fc:ba:67:49:c0 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.865: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.870: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:41:05.870: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:41:05.871: 00:fc:ba:67:49:c0 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:05.872: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.368: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:41:15.368: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 Total msgEleLen = 0
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:41:15.369: 00:fc:ba:67:49:c0 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.370: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.374: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 packet received of length 218 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 Total msgEleLen = 189
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 Total msgEleLen = 112
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 Total msgEleLen = 68
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 Total msgEleLen = 63
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 Total msgEleLen = 58
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:41:15.375: 00:fc:ba:67:49:c0 Total msgEleLen = 49
*spamApTask0: Feb 05 16:41:15.376: 00:fc:ba:67:49:c0 Total msgEleLen = 40
*spamApTask0: Feb 05 16:41:15.376: 00:fc:ba:67:49:c0 msgEleLength = 10 msgEleType = 37
*spamApTask0: Feb 05 16:41:15.376: 00:fc:ba:67:49:c0 Vendor specific payload from AP 00:FC:BA:67:49:C0 validated
*spamApTask0: Feb 05 16:41:15.376: 00:fc:ba:67:49:c0 Total msgEleLen = 26
*spamApTask0: Feb 05 16:41:15.376: 00:fc:ba:67:49:c0 msgEleLength = 22 msgEleType = 37
*spamApTask0: Feb 05 16:41:15.376: 00:fc:ba:67:49:c0 Discovery Request received on wrong VLAN '0' on interface '1', management VLAN = '1', AP Manager VLAN = '1', dropping the packet
*spamApTask0: Feb 05 16:41:15.376: 00:fc:ba:67:49:c0 State machine handler: Failed to process msg type = 1 state = 0 from 1.1.1.23:5248
*spamApTask0: Feb 05 16:41:15.376: 00:00:00:00:00:00 Failed to parse CAPWAP packet from 1.1.1.23:5248
q*spamApTask0: Feb 05 16:41:24.268: 00:00:00:00:00:00 CAPWAP Control Msg Received from 1.1.1.24:5248
*spamApTask0: Feb 05 16:41:24.268: a0:93:51:17:94:00 packet received of length 258 from 1.1.1.24:5248
*spamApTask0: Feb 05 16:41:24.268: a0:93:51:17:94:00 Msg Type = 1 Capwap state = 0
*spamApTask0: Feb 05 16:41:24.268: a0:93:51:17:94:00 Discovery Request from 1.1.1.24:5248
*spamApTask0: Feb 05 16:41:24.268: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 20
*spamApTask0: Feb 05 16:41:24.268: a0:93:51:17:94:00 Total msgEleLen = 229
*spamApTask0: Feb 05 16:41:24.268: a0:93:51:17:94:00 msgEleLength = 73 msgEleType = 38
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 ApModel: AIR-AP1815I-I-K9
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 Total msgEleLen = 152
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 msgEleLength = 40 msgEleType = 39
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 Total msgEleLen = 108
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 41
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 Total msgEleLen = 103
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 msgEleLength = 1 msgEleType = 44
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 Total msgEleLen = 98
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 45
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 Total msgEleLen = 78
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 msgEleLength = 16 msgEleType = 28
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 Total msgEleLen = 58
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 msgEleLength = 5 msgEleType = 1048
*spamApTask0: Feb 05 16:41:24.269: a0:93:51:17:94:00 Total msgEleLen = 49
So what are solution that allow AP1815 join to ME ?????,, and will appear in interface web ME 1815 ???????,
23 Replies 23
 Two advises to get started:  Console into the AP and make sure it is ME capable.  Many times people get lightweight APs and try to join in a mobility express wlc.
Second, try to keep then in the same version code.
-If I helped you somehow, please, rate it as useful.-
1)   AP 1815 ( run 8.3.111 )  and ME run ( 8.8.100 ) ===> 29 AP 1815i and only one ME 1815
so what version runn in AP 1815 that allow AP join to ME  autamatiquement and i that allow i don't have other problem !!
2)  how to set time zone AP and ME because i am from Tunisia so i have more opton !! i don't know what to set !!
Thanks in advance
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.02.05 14:57:11 =~=~=~=~=~=~=~=~=~=~=~=
21. (GMT +5:45) Katmandu
22. (GMT +6:00) Almaty, Novosibirsk
23. (GMT +6:30) Rangoon
24. (GMT +7:00) Saigon, Hanoi, Bangkok, Jakatar
25. (GMT +8:00) HongKong, Bejing, Chongquing
26. (GMT +9:00) Tokyo, Osaka, Sapporo
27. (GMT +9:30) Darwin
28. (GMT+10:00) Sydney, Melbourne, Canberra
29. (GMT+11:00) Magadan, Solomon Is., New Caledonia
30. (GMT+12:00) Kamchatka, Marshall Is., Fiji
31. (GMT+12:00) Auckland (New Zealand)
32. (GMT+10:30) Adelaide, South Australia
(Cisco Controller) config>time timezone location ?
<location_index> Enter the timezone location index.
1. (GMT-12:00) International Date Line West
2. (GMT-11:00) Samoa
3. (GMT-10:00) Hawaii
4. (GMT -9:00) Alaska
5. (GMT -8:00) Pacific Time (US and Canada)
6. (GMT -7:00) Mountain Time (US and Canada)
7. (GMT -6:00) Central Time (US and Canada)
8. (GMT -5:00) Eastern Time (US and Canada)
9. (GMT -4:00) Altantic Time (Canada)
10. (GMT -3:00) Buenos Aires (Agentina)
11. (GMT -2:00) Mid-Atlantic
12. (GMT -1:00) Azores
13. (GMT) London, Lisbon, Dublin, Edinburgh
14. (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
15. (GMT +2:00) Jerusalem
16. (GMT +3:00) Baghdad
17. (GMT +4:00) Muscat, Abu Dhabi
18. (GMT +4:30) Kabul
19. (GMT +5:00) Karachi, Islamabad, Tashkent
20. (GMT +5:30) Colombo, Kolkata, Mumbai, New Delhi
--More-- or (q)uit
--More-- or (q)uit
Incorrect input! Use 'config time timezone location <location-index>'
(Cisco Controller) config>time ?
manual Configures the system time.
ntp Configures the Network Time Protocol.
timezone Configures the system's timezone.
(Cisco Controller) config>time manual ?
<MM/DD/YY> MM/DD/YY - Date portion
(Cisco Controller) config>time manual 02/05/2019 ?
<HH:MM:SS> HH:MM:SS - Time portion
(Cisco Controller) config>time manual 02/05/2019 14:57:02
Invalid Date or Time (check input format!).
(Cisco Controller) config>code ?
Leo Laohoo
PLEASE CALM DOWN.
Stop creating multiple threads of the same topic.
If there are multiple threads of the same topics, we, the volunteers will not know which thread to respond to.
If no one is responding to the threads then it's probably because we can't determine how to help.
If this project is urgent then raise a TAC Case.
Please be reminded that we are all volunteers.
Whats the AP model trying to join ME?
If APs gets correct DHCP and the switch port configured correctly, you can try using the following command on the AP.
capwap ap primary-base <controllername> <controllerip>
How does the AP discover the ME 1815?
Can you provide the output for following:
show ap summary
show ap join stats summary all
show ap join stats detailed <base mac of AP>     --->(base Mac of ap which is not joining)
--- Verify the country code configured on ME WLC.
--- verify the date and time
Can you restart the AP and provide AP console output..
***Please rate all helpful posts***
Jagan
===> AP 1815I ( new 8.3.111) trying to join ME 1815 ( 8.8.100)
toplogie : AP+switch layer 2+ME + routeur ( default gatwy )
But , i don't know if i configured ME ( DHCP ) OR router ( DHCP ) ???????????
ME :
@ip mangement : 1.1.1.21 + 255.255.255.0 + default gatewy : 1.1.1.1
SO ; where i can configure DHCP ?????,,( ME or router )
//// the output for following : i provide you to morrow ) from ME
you can see emprime ecrant ( ME 1815)
I would highly recommend to go through the following Mobility Express Deployment Guide which has step-by-step procedure to install and configure Mobility Express.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-2/b_Mobility_Express_Deployment_guide/b_Mobility_Express_Deployment_guide_chapter_0100.html
makre sure you meet the
As per DHCP, you can use either switch/ME Controllers to assign IPs.
Jagan
Please help me how i can put DHCP on ME  that allow AP get ip address from DHCP ME  correctly ?????,
But i have a  Problem with  router ( DHCP ) and AP get ip from router , so what i can do that AP get ip address from ME 1815 ???????,not from router
ME : ip mangagemnt : 1.1.1.21 with mask 255.255.255.0
gateway : 1.1.1.1
i give print Screen  file interface web DHCP But  interface web 1815 is different then other ME !!
thanks in advance
if i disabled DHCP from router that allow ME get ip addres to AP ???????,,!!
i wait your help please
thanks
From Mobility Express pre-requisites:
Configure a DHCP server on the switch or externally so that Cisco 1800 series Access Point can obtain an IP address at boot up. The DHCP server also assigns IP address to other APs and wireless clients.
So, the recommendation is to have a DHCP server outside ME AP as this AP also require an IP Address. In your case, you can use your switch (if it supports DHCP) or router.
Try to put the ME AP and the rest of APs in same VLAN and use the same device which assigned IP Address to your Mobility Express AP.
I have a question that i don't you understand !!
if i put router as server DHCP so ME 1815   What is his role  !!!! get ip addres from router or it remain ip managment 1.1.1.21 with 255.255.255.0 and gateway 1.1.1. 1
2)  what pool is configured in router that AP discover ME ( WLC ) !!! 1.1.1.22 or 1.1.1.0 /24  !!!!!!!!!!!!!
3)  why ME to be server DHCP ?????,  and disable DHCP on router so my be AP get ip address from ME???,
4) version AP 1815i 8.3.111 and ME 8.8.100 :  is good or not ???,
thanks in advance
Configure a DHCP server on the switch or externally so that Cisco 1815 Access Point can obtain an IP address at boot up.  ME 1815 has two roles here. 1. Wireless Controller 2. Access Point.
ME 1815 configured as WLC is also an Access Point, which requires an IP Address to join itself (WLC). This 1815 AP replies on an external DHCP server to get an ip assigned, so that it can initiate CAPWAP session with self (WLC). The DHCP server also assigns IP address to other APs and wireless clients. So, 1815 AP gets an IP Address from the router & WLC will have the mgmt interface ip address which is 1.1.1.21 in your case.
I don't know your router capabilities, but in general you can configure 1.1.1.0/24 and exclude IPs until 1.1.1.21
https://www.cisco.com/c/en/us/support/docs/wireless/mobility-express/210531-Mobility-Express-Internal-DHCP.html
AP and ME can't run different code versions. You'll need to setup a TFTP server and any AP join the ME will get the software download from it to be in sync with ME.
8.1-8.4 – Not recommended due stability and enhancements done in newer releases
For Mobility Express deployments, TAC recommends using the 8.5.140.0 or 8.8.111.0 release.
***Hope this helps***
Jagan
i would to thanks very much for you help but i have problem :
AP get ip addree from DHCP but interface web  did not appear :
i send output of ME : message i would to tell me what i can doing !! that allow AP appear in interface web : !!
problem !! time or other reason !!! ?????????
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.02.05 13:42:09 =~=~=~=~=~=~=~=~=~=~=~=
Number of APs.............................................. 2
Base Mac AP EthernetMac AP Name IP Address Status
00:fc:ba:67:49:c0 N A AP28AC.9E89.48E0 1.1.1.23 Not Joined
a0:93:51:17:94:00 N A AP780C.F0DB.2A90 1.1.1.24 Not Joined
(Cisco Controller) >show ap summary
Number of APs.................................... 0
Global AP User Name.............................. AP-SOTETEL
Global AP Dot1x User Name........................ Not Configured
Global AP Dot1x EAP Method....................... EAP-FAST
* prefix indicates Cisco Internal AP
(Cisco Controller) >show ap join stats detailed
Incorrect input! Use 'show ap join stats detailed <ap-mac>'
(Cisco Controller) >show ap join stats detailed ?
<Cisco AP Mac> Enter MAC address of the specifc Cisco AP.
(Cisco Controller) >show ap join stats detailed 00:fc:ba:67:49:c0
Sync phase statistics
- Time at sync request received............................ Not applicable
- Time at sync completed................................... Not applicable
Discovery phase statistics
- Discovery requests received.............................. 66
- Successful discovery responses sent...................... 0
- Unsuccessful discovery request processing................ 66
- Reason for last unsuccessful discovery attempt........... Layer 3 discovery request not received on management VLAN
- Time at last successful discovery attempt................ Not applicable
- Time at last unsuccessful discovery attempt.............. Feb 04 01:43:17.019
Join phase statistics
- Join requests received................................... 0
- Successful join responses sent........................... 0
- Unsuccessful join request processing..................... 0
- Reason for last unsuccessful join attempt................ Not applicable
- Time at last successful join attempt..................... Not applicable
- Time at last unsuccessful join attempt................... Not applicable
Configuration phase statistics
--More-- or (q)uit
- Configuration requests received.......................... 0
- Successful configuration responses sent.................. 0
- Unsuccessful configuration request processing............ 0
- Reason for last unsuccessful configuration attempt....... Not applicable
- Time at last successful configuration attempt............ Not applicable
- Time at last unsuccessful configuration attempt.......... Not applicable
Last AP message decryption failure details
- Reason for last message decryption failure............... Not applicable
Last AP disconnect details
- Reason for last AP connection failure.................... Not applicable
- Last AP disconnect reason................................ Not applicable
Last join error summary
- Type of error that occurred last......................... Lwapp discovery request rejected
- Reason for error that occurred last...................... Layer 3 discovery request not received on management VLAN
- Time at which the last join error occurred............... Feb 04 01:43:17.019
Ethernet Mac : 00:00:00:00:00:00 Ip Address : 1.1.1.23
--More-- or (q)uit
(Cisco Controller) >?
apciscoshell Go to AP Console
clear Clear selected configuration elements.
config Configure switch options and settings.
cping Send capwap echo packets to a specified mobility peer IP address.
debug Manages system debug options.
eping Send Ethernet-over-IP echo packets to a specified mobility peer IP address.
grep Print lines matching a pattern.
help Help
linktest Perform a link test to a specified MAC address.
logout Exit this session. Any unsaved changes are lost.
mping Send Mobility echo packets to a specified mobility peer IP address.
ping Send ICMP echo packets to a specified IP address.
reset Reboot (hard reload) options.
restart Restart (soft reload) the switch.
save Save switch configurations.
show Display switch options and settings.
test Test trigger commands
transfer Transfer a file to or from the switch.
i put command in ME 1815
 debug capwap events enable
i send a file for this command
so what problem exactly !!
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.02.05 15:21:07 =~=~=~=~=~=~=~=~=~=~=~=
(Cisco Controller) >debug ca?
cac call-control capwap calea
(Cisco Controller) >debug capwap events enable
(Cisco Controller) >*emWeb: Feb 05 16:28:51.716:
Debugging session started on Feb 05 16:28:51.716 for WLC AIR-AP1815I-I-K9 Version :8.8.100.0 SN :FGL2221B268 Hostname controlleur
*spamApTask0: Feb 05 16:28:57.519: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:28:57.526: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:29:07.711: a0:93:51:17:94:00 Discovery Request from 1.1.1.24:5248
*spamApTask0: Feb 05 16:29:11.782: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:29:11.788: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:29:21.278: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:29:21.287: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:29:30.782: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:29:30.789: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:29:37.168: a0:93:51:17:94:00 Discovery Request from 1.1.1.24:5248
*spamApTask0: Feb 05 16:29:40.286: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:29:40.293: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:29:49.793: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:29:49.807: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:29:59.296: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:29:59.301: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:30:06.630: a0:93:51:17:94:00 Discovery Request from 1.1.1.24:5248
*spamApTask0: Feb 05 16:30:13.556: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:30:13.563: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:30:23.056: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
*spamApTask0: Feb 05 16:30:23.063: 00:fc:ba:67:49:c0 Discovery Request from 1.1.1.23:5264
q
Incorrect usage. Use the '?' or <TAB> key to list commands.
(Cisco Controller) >*spamApTask0: Feb 05 16:30:36.088: a0:93:51:17:94:00 Discovery Request from 1.1.1.24:5248
(Cisco Controller) >undu    ?
help Help
(Cisco Controller) >no du  deb      debug ndebug odebug   deb*spamApTask0: Feb 05 16:31:05.563: a0:93:51:17:94:00 Discovery Request from 1.1.1.24:5248
e
(Cisco Controller) >no debe ug        undebug ?
(Cisco Controller) >undebug
(Cisco Controller) >*spamApTask0: Feb 05 16:31:35.020: a0:93:51:17:94:00 Discovery Request from 1.1.1.24:5248
If ME AP/WLC and other APs are on same Layer 2 network, they'll discover the ME WLC by local broadcast.
Prep your ME by following the steps from the link below.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-2/b_Mobility_Express_Deployment_guide/b_Mobility_Express_Deployment_guide_chapter_01010.html
