Highlighted
Beginner
Joining AIR-CAP-2602-E2-K9 to WLC 2504
I just received a 2504 WLC and a few AIR-CAP2602-E2-K9 APs. I resetted the WLC and have that up now, reachable using the first network port.
In port 3, the first PoE, I have one of the access points. I can't see it in the WLC admin gui, Im guessing I must config the network port of the wlc and on the AP manually choose to join the WLC or such. The AP also has some old password so that need to be resetted.
Can anyone direct me to documentation for resetting an AP & joining an AP in a WLC?
Thanks in advance
3 REPLIES 3
VIP Mentor
Hi ,Best is to have AP
Hi ,
Best is to have AP connedcted tos wicth port not directly to WLC.
1. Connect AP to switch port.
2. Create a DHCP pool for AP to get IP on switch(Try to keep in same subnet as WLC)
Dont forget to rate helpful posts
Beginner
I have one AP joined now -
I have one AP joined now - thanks. It gets an address from the dhcp server in the management network. I setup one WLAN using wpa2 PSK method. When a client connects, it doesn't get any ip. Im guessing the SSID/WLAN in question must be tied to either some tagged vlan, or simply to the untagged mgmt vlan that the APs sit on. Please advise!
The ap:
ap#show ip interface
BVI1 is up, line protocol is up
  Internet address is 10.99.0.250/24
 Broadcast address is 255.255.255.255
My workstation can reach it:
$ ping 10.99.0.250
PING 10.99.0.250 (10.99.0.250): 56 data bytes
64 bytes from 10.99.0.250: icmp_seq=0 ttl=255 time=2.941 ms
VIP Mentor
Hi,I setup one WLAN using
This WLAN is mapped to whcih interface ??(Management or on any other dynamic interface ?)
Try to create a another dynamic interface in sepearte vlan then map this dynamic interafce to wyour WLAN.
Make sure you allow this wlan to wlc connected port on switch.
Content for Community-Ad
August's Community Spotlight Awards
