Joining CISCO AP 1041N to a WLC 2500 Series
ranimbouraoui
I have a problem joining 10 CISCO AP's 1041N to a WLC 2500 Series.
I have the following network architecture,
A Windows Server 2012 R2 (DC, DHCP and DNS Server) connected to CISCO 2960-X Series (This switch is connected to 2 other switches, same model), the 10 AP's and the WLC are connected to the same Switch, as I have 3 NIC's on the Server I am using one for Internet from the Firewall and the three others are teamed together and connected to the Switch.
I tried the following methods:
- I used the Option 43 on the DHCP Server: Not Working
- I added 2 DNS Entries (cisco-capwap-controller.mydomain and cisco-lwapp-controller.mydomain) : not working
- UDP Ports for CAPWAP and LPWAP are enabled on the Windows Firewall : not working
My WLC is set in Master Controller Mode, I can see all the AP's in the DHCP Server with their IP's affected by the server and the WLC as well, and they can ping on each other.
In addition, on the WLC, I have one interface (management) with VLAN ID 0, the Server have (Default VLAN) no ID affected, the Switch have VLAN ID 1 (Default), and I tried to change all of them to the same VLAN ID 1 (Server, Switch, WLC) in that case the server is not able to communicate with all of them and DHCP is not working.
Thank you for your help.
Oh, your APs are in autonomous mode, thats why they cannot join to the WLC. You have to convert them to lightweight! Here is a good guide - http://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
6 Replies 6
MUQ_1899_
Try to configure the IP address of the WLC static on the APs: capwap ap controller ip address x.x.x.x
Do you have enaugh AP licenses on the controller ?
Thanks for the answer, I have enough licenses for the WLC (10 in total)
I tried the command and I got the following message
ap#capwap ap controller ip address  192.168.1.7
% Invalid input detected at '^' marker.
ap#
Everything is up and running, I installed the image on the AP's and they are able now to join the controller using Option 43.
Maybe this could help,
ap#show config
Using 1410 out of 32768 bytes
! Last configuration change at 01:51:07 +0100 Mon Mar 1 1993
! NVRAM config last updated at 16:13:39 +0100 Tue Mar 8 2016
version 15.2
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$y5QZ$DZktb35zppTUCcDq4fCNM1
no aaa new-model
clock timezone +0100 1 0
no ip routing
no ip cef
dot11 syslog
username Cisco password 7 096F471A1A0A
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 shutdown
 antenna gain 0
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 no keepalive
 bridge-group 1
interface BVI1
 ip address dhcp client-id GigabitEthernet0
 no ip route-cache
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
 login local
 transport input all
end
My WLC have the IP 192.168.1.7
The AP's have the range starting from 192.168.1.8 to 192.168.1.17
Sandeep Choudhary
Paste the information:
sh version from AP
sh sysinfo from WLC
Also paste the logs from cisco AP console .
Dont forget to rate helpful posts
