Highlighted
Beginner
LAP's loose connectivity to WLC
I have an enterprise wireless solution with three WLC's in the corp office and about 160 LAP's around the US. The sites are connected via MPLS network. The issue is everytime the MPLS is down, some of the LAP's looses the connection to the WLC and will not establish the connection back again when the MPLS is back up and running. I have to manually reboot the LAP's to re-connect back with the WLC.
Any feed back is so appreciated.
Ayman
Everyone's tags (3)
10 REPLIES 10
Highlighted
Hall of Fame Master
Re: LAP's loose connectivity to WLC
Ayman,
Can you please provide the wlc model, ap model an wlc code you are running. It might help if others have the same setup.
-Scott
Highlighted
Beginner
Thank you Scott for your reply. Here is the info you requested.
WLC Model:  AIR-CT5508-K9
AP Model: AIR-CAP3502I-A-K9
Code Version: 7.0.116.0
Let me know if you need any further info.
Highlighted
Hall of Fame Community Legend
Upgrade your code to either 7.0.235.0 or 7.2.X and try again.
Highlighted
Beginner
hello
have you confiugred controller info. in ap high availability as a primary controller.
if not configure it this may helpful for you.
thanks
Highlighted
Beginner
Yes, All AP's are configured with primary and secondary controller. The weird thing is that not all AP's behave the same, some of them do re-associate with the controller and other won't.
Highlighted
once the mpls come up does the ap switch from standalone to connected mode/trying to join the wlc. do you've log/debug to see the same.
check the deployment guide for the hreap requirement across wan.
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080736123.shtml#Design
Highlighted
Beginner
Does the problem stick with the same APs each time or is it random? When the problem occurs, can you reach the APs by IP?
Highlighted
Beginner
I haven't really paid attention whether the problem sticks to the same AP. I will watch it. The AP is reachable when this occurs as I do see it thru the switch that connected to it with a valid IP address.
Highlighted
Beginner
Any chance your problems are the result of high latency caused by a back log of traffic? HREAP APs won't associate if latency is above a certain threshold.
Highlighted
Beginner
Good question! I have checked for latency but the MPLS bandwidth shows enough bandwidth and no latency. I am in process of upgrading the code to 7.2.110 and I will update the ticket later on.
Content for Community-Ad
