2126
Highlighted
LAP1252 to AP1252 update and ping problem
Hi the list !
Since i've replaced the Lightened Access Point IOS (12.4) to the Autonomous Access Point IOS (12.4) i'm not able to ping anymore the ethernet interface.
My computer is directly connected to the AP-1252, the link is up and IP properly configured. AP-1252 is 10.0.0.1/16 and computer is 10.0.0.2/16.
ping from computer to AP-1252 => timeout
ping from AP-1252 to computer => % Unrecognized host or address, or protocol not running.
any idea ?
I use the default IOS configuration except ip address settings and ip http server (not secured), note that i'm not able to access the web configuration interface too...
Kind regards,
Amaury
Everyone's tags (3)
1 ACCEPTED SOLUTION
Rising star
Re: LAP1252 to AP1252 update and ping problem
Hi Amaury,
The ip address should be on the bvi interface and not on gig interface. Try reconfiguring ap as below
interface GigabitEthernet0
no ip address 10.0.0.1 255.255.0.0
interface bvi1
Else with your as is configuration you need to have a dhcp running on the laptop which corresponds to ip subnet 10.0.0.x network the bvi interface would pick an ip address from this dhcp scope. AP would respond to ping only when it have a valid ip on the management interface that is bvi1 interface
Hope that helps
Najaf
8 REPLIES 8
Rising star
Hi Amaury,
Could you please provide the AP full configuration and "show ip int brief" output?
Najaf
Hi Najaf, thanx for answer
ap#show running-config
Current configuration : 1411 bytes
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 $1$QcCw$ThfcKVWDZh1GNxFQfhjDy.
no aaa new-model
dot11 syslog
username Cisco password 7 032752180500
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
ip information-reply
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
ap#show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       unassigned      YES DHCP   down                  down
Dot11Radio0                unassigned      YES NVRAM  administratively down down
Dot11Radio1                unassigned      YES NVRAM  administratively down down
GigabitEthernet0           10.0.0.1        YES NVRAM  up                    down
regards,
Amaury
Rising star
Hi Amaury,
interface bvi1
Hope that helps
Najaf
Thank you Najaf,
Things going better but i'm still not able to ping my AP or access to its web interface configuration.
Now when i ping the AP i'm getting the following on console with debug ip icmp on :
ap#debug ip icmp
ICMP packet debugging is on
ap#
*Mar  1 01:26:51.447: ICMP: echo reply sent, src 10.0.0.1, dst 10.0.0.2
*Mar  1 01:26:58.343: ICMP: dst (10.0.0.1) port unreachable sent to 10.0.0.2
*Mar  1 01:27:01.087: ICMP: dst (10.0.0.1) port unreachable sent to 10.0.0.2
I get request timeout on computer.
and following while pinging from AP :
ap#ping 10.0.0.2
Sending 5, 100-byte ICMP Echos to 10.0.0.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
BVI1                       10.0.0.1        YES NVRAM  up                    up
GigabitEthernet0           unassigned      YES NVRAM  up                    up
SAMPLE FROM RUNNING CONFIG
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
no ip route-cache
hope this helps,
Amaury
Rising star
Hi Amaury,
Couple of things to check here.
1) Are you using a cross over cable or straight cable to connect between AP and Laptop?
2) Disable any firewall (including windows firewall) or antivirus on the laptop and try pinging between two.
Also get the output of "show arp" from AP
Najaf
Hi Najaf,
i'm using a 4 pairs straight cable since mi laptop interface is gigabit and autosense, the link is up
i don't use any firewall (windows FW disabled too) or antivirus
the arp table follows :
ap#show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.0.0.2                0   0011.2587.7a69  ARPA   BVI1
Internet  10.0.0.1                -   001d.4591.41ac  ARPA   BVI1
strange facts...
cheers,
Amaury
OK !! everything running good !!!
I've changed my 4 pairs straight cable against a 2 pairs straight cable
strange but working fine !
thank you very much for help
kind regards,
Amaury
Everythng OK, see upper message.
Thank you very much for help, the right way whas the BVI interface as you said..
Amaury
Content for Community-Ad
August's Community Spotlight Awards
