02-28-2013 12:05 AM - edited 07-03-2021 11:38 PM
Is there any possibility to limit the bandwidth per SSID on Cisco Aironet 1100 that is connected to Cisco router 876?
So the main goal is to have two SSID one for the guests and one for the colleagues and to limit for example half the bandwidth of internet link per SSID so we dont get into situation that colleagues overload whole internet link so that guests can always surf without problem.
02-28-2013 12:47 AM
Few Facts:
IF you are talking about autonomous AP:
- Upstream traffic from the wireless client
QoS for wireless LANs does not affect this traffic.
-The Ethernet upstream flow is traffic sent from the access point Ethernet port to a switch or router on the wired LAN. The access point does not prioritize traffic that it sends to the wired LAN based on traffic classification.
Based on the above , if you want to divide the bandiwdth from two ssids users accessing the internet
you have to define two clss maps , based on the source ip address subnet given that every ssid is mapped to different vlan , hence different subnet . This should be done on the first l3 hop device .
based on the two class maps you have to configure policing based on the internet available bandwidth .
Please Don't Forget to Rate correct answers
02-28-2013 02:53 AM
Dear Maldehne,
Upstream traffic sent from Access Point is not our concern - only the downstream.
As I have no experience with class and policy maps - could you please help me creating this two class maps?
I have read the Cisco guide to configuring class maps and policy maps, but unfortunately I cant figure out how could I create the necessary..
02-28-2013 03:33 AM
well, you need to create two ACLs
one ACL to match traffic sourced by certain subnet that represent clients on ssid 1
another ACL to match traffic sourced by the other subnet the represent ssid 2
Then you create two class maps and use to match the ACL that is alligned with each class
configure policing based on the classes the you have created using policy map
Then apply it
05-21-2015 10:56 PM
Go through the below link
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/113682-bdr-limit-guide-00.html#pro2
I haven't come across this type of issue
But information is provided on below link is complete, so where you are stucking ?.
- See more at: https://supportforums.cisco.com/discussion/12232701/rate-limit-wireless-guest-traffic#comment-10518511Hi,
- See more at: https://supportforums.cisco.com/discussion/12232701/rate-limit-wireless-guest-traffic#comment-1051851105-22-2015 07:32 AM
You can use QOS to do this. When you configure QoS on the access point, you can select specific network traffic, prioritize it, and use congestion-management and congestion-avoidance techniques to provide preferential treatment. Implementing QoS in your wireless LAN makes network performance more predictable and bandwidth utilization more effective. For more information on this read the document available at http://www.cisco.com/c/en/us/td/docs/wireless/access_point/12-2_11_JA/configuration/guide/b12211sc/s11qos.html
