11-09-2017 12:35 AM - edited 07-05-2021 07:50 AM
Is it possible to limit the unsuccessful ssh attempts to for MGMT access on the WLC (software version 8.5.105)? I would like to limit the unsuccessful attempts to 3 in a row.
Solved! Go to Solution.
11-09-2017 01:05 AM
I dont think you can limit the unsuccessful attempt on WLC.
Only these config possible : Go to
Management > Telnet-SSH
Dont forget to rate helpful posts
11-09-2017 01:05 AM
11-09-2017 01:39 AM
@Leo Laohoo wrote:
after 3 unsuccessful SSH attempt any device will kick you out.
Currently the WLC is 5 unsuccessful attempts during SSH not the requested 3.
11-09-2017 01:05 AM
11-09-2017 01:38 AM - edited 11-09-2017 01:40 AM
Documentation guide for 8.5.105 doesn't have that for an option. Looks like you're correct.
11-09-2017 01:41 AM
As I told ...it not possible to set the limit on WLC.
