09-15-2020 06:29 AM - edited 07-05-2021 12:30 PM
I wonder how can I get list of end of life access points (2021) that are currently registered with my WLC 5508. Please advise.
Thank you.
Daniel
Solved! Go to Solution.
09-15-2020 05:04 PM
Every terminal client (putty, SecureCRT, etc.) have an option to log terminal output into a text file.
Use the following CLI command to generate the list:
config paging disable sh ap summary
09-15-2020 06:40 AM
That will depend on the firmware of the controller.
09-15-2020 06:42 AM
The current software version is:
Software Version 8.3.112.0
09-15-2020 06:51 AM - edited 09-15-2020 06:53 AM
09-15-2020 06:53 AM
You can do with Prime, but never tried from WLC.
WLC you can list the model and check against Model - is this works or you looking some script to generate you looking ?
09-15-2020 07:15 AM
- If you take into account the ap-only , you can also use :
https://cway.cisco.com/sncheck/
M.
09-15-2020 07:27 AM
From what I could see The Check Device Coverage does not provide information about end of life.
You can only see end of sale and end of support. Thanks.
09-15-2020 07:37 AM
End of Support and End of Life are the same.
09-15-2020 08:16 AM
- Exactly ,
M.
09-15-2020 08:28 AM
Is there an option to export all APs list from WLC? Thank you
09-15-2020 05:04 PM
