Highlighted
Beginner
Locally switched vlans
I have an issue with some of my 1250 AP's with software 7.0.98.0 12.4(23c)JA connect to my  5510 controller will randomly get the locally switched vlans that are assigned to it to be mixed up.  Sometimes I can have 20 APs at one site and one or all those AP's will have the vlans mixed up. To fix I have to go back into Cisco WCS and rerun the configuration template against those AP's.  What is causing this and what is the fix?
Everyone's tags (3)
1 REPLY 1
Highlighted
you're hitting below bug. updating the code to latest 7.X or any of the mentioned bug will fix the issue, by the way 7.0.98.0 is an deferred code.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsw68997
Content for Community-Ad
