Community Helping Community
538
Hall of Fame Community Legend
Re: Looking to upgrade our Cisco Wireless solution
Same way with licensing. You can get add-on license for future growth.
Beginner
Yes you order licenses as usual. Just the deployment changed since 3504/5520 WLC as they use "right-to-use" licensing. AKA you just confirm the WLC you have the licenses, allowing deployment/replacement in real time without further paperwork.
Beginner
I probably should clarify my question on licensing. It is still by AP. Correct?
Hall of Fame Master
It is licensed by AP count.
-Scott
VIP Advocate
Yes it is. Please also have a look at Cisco One licensing model. It's a bit more expensive, but includes Prime Infrastructure, MSE and other product licenses. You might even get a good upgrade offer for it.
Highlighted
Beginner
Just curious, Does Cisco offer any Virtual controllers that would fit my needs?
Hall of Fame Master
There are virtual controllers but your design might change with those. Also the hardware requirements need to be there for full TAC support. It really comes down to your overall design. Then you should be able to narrow down what you should implement.
-Scott
Beginner
There is a Virtual WLC, but it's more for small setup or to control AP in branch offices via VPN, where AP are supposed to work even the controller is unreachable.
In your case with stable 1G/10G-LAN and redundant WLC, I personally recommend to do it in classical way with hardware WLC and AP in local mode. Majority of the cost will be caused by the AP license for the WLC and not by the base controller itself, no matter virtual or hardware.
Content for Community-Ad
August's Community Spotlight Awards
