12-05-2012 01:51 AM - edited 07-03-2021 11:10 PM
Dear All,
I have WLC 2504 with 7.2.103.0 software version , & 2 different LWAP 1262n & 1231G with "c1200-rcvk9w8-mx.124-21a.JA" Image.
The 1262n is joined to the to the controller and working fine but the 1231G it cann't join the controller , the controller says "Join request received from an unsupported AP" !!
i will attaches the logs for this AP.
please can any one help.
Solved! Go to Solution.
12-05-2012 01:56 AM
If you want to use 1230, then the "highest" WLC version you can run is the 7.0.235.3.
It says so in the Release Notes under the heading Software Release Support for Access Points, Table 1-1.
12-05-2012 01:56 AM
12-05-2012 02:20 AM
Thanks alot, I got it.
BR
12-05-2012 02:48 AM
Thanks for the ratings.
