05-08-2018 07:15 AM - edited 07-05-2021 08:36 AM
Dear Team,
My AP speed needs to be change to 1000, i tried on the switch end from auto to 1000. But no luck, interface automatically went down.
Gi7/0/12 5S-006C WAP2 connected 65 a-full a-100 10/100/1000BaseTX
Hence i tried to login in to AP. But unable to login, hence kindly guide me, how to do ?
05-08-2018 07:20 AM
05-08-2018 07:53 AM
I am getting below output,
please share your input.
show cable-diagnostics tdr int gi 7/0/12
TDR test last run on: May 08 10:42:44
Interface Speed Local pair Pair length Remote pair Pair status
Gi7/0/12 100M Pair A N/A N/A Not Completed
Pair B N/A N/A Not Completed
Pair C N/A N/A Not Completed
Pair D N/A N/A Not Completed
wlc ---> i am executed below command, i am getting below error.
(Cisco Controller) >config ap ethernet duplex 0 speed 1000 ap_1
This command has been deprecated from 8.1 release.
Note :
Here concern i AP is working fine with 100 Mbps.
05-08-2018 07:57 AM
05-08-2018 07:59 AM
05-08-2018 08:52 AM
No getting below error,
05-08-2018 09:05 AM
05-08-2018 09:50 AM
Please see the available command,
(Cisco Controller) config>ap ethernet ?
0 Ethernet interface number
1 Ethernet interface number
2 Ethernet interface number
3 Ethernet interface number
duplex Configure Ethernet Port Duplex Settings
tag Configures vlan tag feature
(Cisco Controller) config>ap ethernet 0 ?
mode Enter Access or Trunk
05-08-2018 09:58 AM
05-09-2018 04:46 AM
hi jitter
i tried below command, but still getting same error,
config ap ethernet duplex full speed 1000 ap_1
05-09-2018 01:18 PM
05-08-2018 09:05 AM
If it didn't support the TDR command, you wouldn't get the output from that show command. As it says "Not Completed," you need to wait a bit longer and rerun the show command. The test isn't an instant test - it takes some time. Rerun the test, wait a minute, then run the show command. If it still shows "Not Completed," wait a few seconds then rerun the show command.
05-08-2018 10:26 AM
ok sure thanks for ur info, i will check and let you know.
05-08-2018 02:05 PM
What is the model of the AP?
Post the complete output to the command "sh int g7/0/2 controll".
05-09-2018 04:44 AM - edited 05-09-2018 04:45 AM
model : AIR-LAP1142N-A-K9
Command output
#sh int gi 7/0/12 controller
GigabitEthernet7/0/12 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is a493.4ce6.b48c (bia a493.4ce6.b48c)
Description: 5S-006C WAP2
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:45, output 00:00:31, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 59693768
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 1 packets/sec
5 minute output rate 10000 bits/sec, 5 packets/sec
1767356177 packets input, 755247167033 bytes, 0 no buffer
Received 3140598 broadcasts (2407024 multicasts)
0 watchdog, 2407024 multicast, 0 pause input
3253764581 packets output, 1984759446722 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Transmit GigabitEthernet7/0/12 Receive
484563746 Bytes 3627890698 Bytes
3219624140 Unicast frames 1764215582 Unicast frames
31037094 Multicast frames 2407024 Multicast frames
3103383 Broadcast frames 733574 Broadcast frames
0 Too old frames 2712475878 Unicast bytes
0 Deferred frames 868133126 Multicast bytes
0 MTU exceeded frames 47281694 Broadcast bytes
0 1 collision frames 0 Alignment errors
0 2 collision frames 0 FCS errors
0 3 collision frames 0 Oversize frames
0 4 collision frames 0 Undersize frames
0 5 collision frames 0 Collision fragments
0 6 collision frames
0 7 collision frames 2577493 Minimum size frames
0 8 collision frames 79045170 65 to 127 byte frames
0 9 collision frames 1143300744 128 to 255 byte frames
0 10 collision frames 142708610 256 to 511 byte frames
0 11 collision frames 78604383 512 to 1023 byte frames
0 12 collision frames 321119780 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 0 Pause frames
0 15 collision frames
0 Excessive collisions 0 Symbol error frames
0 Late collisions 0 Invalid frames, too large
0 VLAN discard frames 0 Valid frames, too large
0 Excess defer frames 0 Invalid frames, too small
670813535 64 byte frames 0 Valid frames, too small
216825119 127 byte frames
812840908 255 byte frames 0 Too old frames
411533523 511 byte frames 0 Valid oversize frames
80378421 1023 byte frames 0 System FCS error frames
1061373111 1518 byte frames 0 RxPortFifoFull drop frame
0 Too large frames
0 Good (1 coll) frames
0 Good (>1 coll) frames
