Community Helping Community
1136
Beginner
LWAP to Autonomous
I have a new CAP-3500 series access point and i need to convert it to autonomous since my controller has not yet arrived.
i know for the fact that it can be done on 1200 and 1100 series AP but i am not sure if it is still possible with newer model APs.
I cannot find a document saying that it is also working for these new AP models.
Please help. Thanks!
Everyone's tags (2)
2 ACCEPTED SOLUTIONS
Hall of Fame Community Legend
LWAP to Autonomous
Site-Survey Only Mode for 3600, 3500, and 1550 Access Points
You can install Cisco IOS Release 15.2(2)JA on Cisco Aironet 3600 and 3500 Series access points and on 1550 series outdoor access points to perform site surveys. This release runs on these access points with limited functionality. You can manually adjust these settings on the site-survey access points:
Channel on each radio
Transmit power on each radio
Enable and disable the radios
Manually set basic and supported transmit rates
Enable advertised cell power in beacons to client to enable DTPC for doing active surveys
Enable and disable SSID broadcast in beacons
Enable open authentication
If you have a valid Service Contract then you can download the IOS from here.
LWAP to Autonomous
I have successfuly converted it to the 15.2 version, at first i tried the earlier version of the Autonomous IOS but it was looking for "k9w7" which only 15.2 version has, so i was not successful in converting to lower version.
You can't run autonomous IOS version 12.X for the 3500.
But as the note said that 15.2 version is site survey mode only. what will be the impact of this for the production?
I was able to configure basic single SSID with WPA2-PSK. but what are the limitations for the "site-survey only mode"? will it support raidus authentication and multiple SSID broadcast?
It wasn't meant to go into wifi production, take note of that.   You're probably the first I've read who wants to run autonomous IOS as a service.  I'd strongly recommend you wait for your WLC.
18 REPLIES 18
Beginner
Re: LWAP to Autonomous
There is iOS code for this AP ... You have to download it from Cisco with your cco account.
LWAP to Autonomous
Beginner
LWAP to Autonomous
does this means that for 3500 series that it will only run on site-survey mode and will not have full autonomous capability?
LWAP to Autonomous
You can run a 3500/3600 to provide wi-fi service but CleanAir is disabled.
Leo -- Correct me if I am wrong .. But Cisco is not recommending autonmous mode for these APs in production. Only site survey .. ??
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
LWAP to Autonomous
You're right, George.  Autonomous wifi service not "recommended" but it works.
The OP did say that his controller has "not yet arrived", hence my response.
Beginner
Hi Leo,
Also can i downgrade it to 12.4 version?
LWAP to Autonomous
Beginner
the problem is the finance is holding up the business's budget, i was just trying to help out since they badly need the wifi service and the budget release is still on approval. and no one knows when it will be approved.
LWAP to Autonomous
I haven't tried this but I do not believe RADIUS stuff will be supported.
Beginner
LWAP to Autonomous
OK thanks a lot. I will just try this next week.
A little birdie told me the 15.X autonomous IOS (aIOS) for the 3500, 1600/2600/3600 is a FULL IOS with Spectrum Expert.  So yes, you can do RADIUS.
Apparently, the GUI is alot better.  Give this a try!
Beginner
wow that will be great. this will be very useful for us. Kindly give my thanks to the little Birdie too
Be careful if you are doing 802.1q as I believe there is a potential bug.  I'm trying to raise a TAC Case.  Will let y'all know.
Content for Community-Ad
August's Community Spotlight Awards
