173
Beginner
Mangment vlan
Dear Team,
I just need to create one management vlan so I can assign ip to switches so can you please suggest how can we create management vlan in cisco 3750 its my core switch.
3 REPLIES 3
Beginner
Re: Mangment vlan
 just create a Switch virtual interface with the following commands and than add the Mangement vlan as your native vlan to all trunk interface
Vlan #
name Mangement
exit
interface vlan #
description Management
Ip address #.#.#.# subnet mask
interface g#/#
switchport mode trunk
switchport trunk native vlan #
switchport trunk allowed vlans #,#,#
Beginner
Re: Mangment vlan
Dear Bernhard82,
Please let me know what  is the use of below command.
Highlighted
Beginner
Re: Mangment vlan
The native VLAN is something that the IEEE 802.1Q trunking protocol describes as part of the protocol, and its just a VLAN in wich all traffic sent and received on an interface that is configured for 802.1Q won’t have a tag on its Ethernet frame.
Thats it, if you have configured a native vlan 10, all the frames that arrives in that VLAN and that need to traverse a trunk port, will have its tag removed and pass like it was an access port. All the other VLAN will be tagged normally.
You can see more about it here: https://networklessons.com/switching/802-1q-native-vlan-cisco-ios-switch/
Content for Community-Ad
August's Community Spotlight Awards
