07-28-2015 05:50 AM - edited 07-05-2021 03:39 AM
Have a customer who is rolling out WiFi to many sites with thousands of APs.
What is the maximum number of APs performing a CAPWAP join that the 8510 can simultaneously support?
Is this consistent across all controller models and software versions?
Is there a link to such data?
Thanks in advance.
07-28-2015 05:59 AM
I don't think there is such data. The WLC's will be able to support up to the license count that is allowed. So that being said, if the controller supports 1000 access points and you reboot the controller, then eventually all the access point will join maybe within 5 minutes of the controller being functional and able to be discovered.
-Scott
07-31-2015 05:41 AM
Thanks for all your input. I have now found this PDF
http://cisco-pvt.com/wp-content/uploads/2012/04/CiscoFlexconnect.pdf
Which states that for version 7.2 firmware
Data Sheet | 7500 | 5508 |
Concurrent AP Joins | 1000 | 500 |
Concurrent AP Image Downloads | 1000 | 500 |
So I presume the 8510 is something similar
07-31-2015 06:54 AM
Excellent document .... Yes..8510 is the elder brother of 7510 when it comes to strength and speed ... However, do remember that this presentation is by a Channel systems Engineer .. We all know the difference between the Marketing guys' words and the actual data.. ;)
Cheers,
Manish
07-28-2015 10:58 AM
Hi Scott,
8510 WLC can support up to 6000 AP's.
http://www.cisco.com/c/en/us/products/collateral/wireless/8500-series-wireless-controllers/data_sheet_c78-713207.html
Similarly you can check the datasheet of other WLC models to know the maximum number of AP's they can support.
This link also might be useful :-
http://www.cisco.com/c/en/us/products/wireless/wireless-lan-controller/index.html?referring_site=smartnavRD#~Products
Do let me know if you have any queries or concerns.
Shubham
Don't forget to rate helpful posts and also mark this question as answered.
07-29-2015 03:39 AM
Thanks for the info but this is not what I am asking.
With a large rollout at a number of sites we wish to know the timescales involved with NEW APs registering on the controller and configuring them etc.
I am sure the WLCs can only manage a fixed number of concurrent CAPWAP registrations at a time - e.g. join request, download software etc, rejoin ready for config.
What is the max number of 'new' CAPWAP registration requests that the 8510 can simultaneously handle? And is this documented per device model/firmware version?
07-31-2015 04:15 AM
Adding to what Scott has mentioned , I would say that this would depend on a few factors: The traffic congestion/latency between the APs and the WLC, the bandwidth available between the WLC and the APs. When you say, "thousands of APs", I assume that a lot of them may be across a WAN link and others may be local to the WLC. The local ones would be the faster ones to join and download the firmware. The offsite APs may take varied time depending on the latency and bandwidth. As far as the WLC is concerned, it is expected to respond to a maximum 6000 (as per Cisco claims) CAPWAP join requests at the same time. However, my personal experience says, that if you have 2000 APs trying to join an 8510, please arrange for a window of at least 1 hour.
HTH,
Cheers,
Manish Mathur
07-31-2015 04:35 AM
Aaah.. my bad.. I missed the last part of your query:
"What is the max number of 'new' CAPWAP registration requests that the 8510 can simultaneously handle? And is this documented per device model/firmware version?" ..
That's the most dreaded question for any OEM.. ;) .. First, I haven't seen any documentation mentioning that number. Second, even if there is one, you would not like to arrange the installation window depending on that.. What documents say and what actually happens in the field "MAY" not always be the same.. .. So, my educated guess (backed with personal experience) says that the 8510 has a pretty solid CPU and memory resource and 1 hour should be more than enough for associating at least 2000 APs ...
Cheers,
Manish
07-29-2015 02:27 AM
8500 Series offers enhanced uptime for high-scale deployments with support for:
● 6000 access points and 64,000 clients in a 1RU form factor
● 4096 VLANs for large-scale deployments
● Sub-second access point and client failover for Service Set Identifier (SSID) high availability
● Dual-redundant power supplies installed (AC or DC)
● Dual-redundant 10 Gigabit Ethernet connectivity
