Mesh with WLC (7.0.220)
kri.chi.85
Dear Tech Gurus,
       Can any one help me regarding channel assignament at root and mesh access points.
will the channel be same on all RAPS and MAPS (5Ghz).
With Regards,
Chaitanya.G
Scott Fella
Your RAP's should be on different channels. So it will depend on how far apart your RAP's will be apart from each other to get the channel separation you need. Your MAP's will be assigned the same channel as the parent RAP. Makes sense?
Scott Fella
Sent from my iPhone
-Scott
Scott Fella
Take a look at this doc for reference.
http://www.cisco.com/en/US/docs/wireless/technology/mesh/7.0/design/guide/MeshAP_70.html
-Scott
