migrating the configuration 2821 router to 3925
Hi ,
I need help am planning to migrate the configuration from 2821 isr to 3925 , i want to know is there any challenges are there while migrating.
2 Accepted Solutions
Sandeep Sharma
Hi Vasant,
I think there will not be any major challenges in migration just you need to consider the type of card and link you are using on the router. However use the below link that will give you the major techspec difference in ISRG1 & G2 routers.
http://www.cisco.com/c/dam/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/aag_c45_556315.pdf
Thanks & Regards
sandeep
Muhammad Munir
Level 5
Level 5
Please go through the following link and follow the steps, I hope you will not face any major challenges:
http://www.cisco.com/c/en/us/td/docs/routers/access/2800/2821/notes/fan_installation/2821_fan_installation.html
Sandeep Sharma
Hi Vasant,
Thanks & Regards
sandeep
thanks yaar ...
Muhammad Munir
Level 5
Level 5
