Community Helping Community
1229
Migration from WLC 2504 to Virtual Controller
HI, I would like know how can I do a migration from WLC 2504 to WLC Virtual.
We will migrate the Access Points to, from 1140/1240 to 2700 model.
Thanks.
2 ACCEPTED SOLUTIONS
VIP Mentor
Re: Migration from WLC 2504 to Virtual Controller
"Do you know when doing migrating to FC if we have lost connection on Network? If yes, how many time for maintenance windows I´ll need?"
If you are running 8.0 or above on your 2504, then AP won't reboot when converting to FC. Otherwiese AP has to reboot during the conversion."
I would sugget you to test this out with one AP & familiar with all steps involve, then work out the total maintenance window required
Rasika
*** Pls rate all useful responses ***
I only replicate manually the configurations from one to other Controller.
6 REPLIES 6
Lots of more information would be necessary in order for someone here to give you a reasonable advise.
 The botton line is very simple. Set up vWLC, reply the configuration from 2504 to vWLC, move APs.
 Which specific doubt do you have?
Highlighted
Thanks for answer Flavio.
So I have 20 Access Points between 1140 and 1240 with WLC 2504, I need migrate all equipaments for Access Point´s 2700 with vWLC.
I have two ways:
1. Reconfigure all features from 2504 to vWLC, with 1140 and 1240 and migration from AP(1140/1240) to AP(2700);
2. Do a backup of 2504 and restore on vWLC with 1140 and 1240 and migration from AP(1140/1240) to AP(2700);
One friend adviser-me about the certificate on second option.
Douglas Pereira
VIP Mentor
vWLC only support FlexConnect mode APs, so you need to plan for FlexConnect mode conversions if APs currently are in local mode.
Since vWLC always recommend to deploy with FlexConnect local switching, you have to redesign your wireless with correct IP ranges to support it.
Rasika
Hi Rasika, thanks for answer.
I´m checking how migrate the AP to FC mode, this is it really the first step.
thanks a lot.
Douglas Pereira
VIP Mentor
Rasika
Content for Community-Ad
August's Community Spotlight Awards
