01-30-2019 01:51 AM - edited 07-05-2021 09:46 AM
Dear Mates,
Kindly support me We have cisco access points 2802, But we don't have wireless controller.
Must transfer IOS from light weight to mobility express after we transferred and took right configuration and IP from DHCP all thing is right about configuration when we try to access GUI don't open.
after search we find this command must write at controller CLI ( config network webmode enable ) / save config .
Still GUI don't work any one facing this issue or have any solve.
02-02-2019 12:29 PM
Hay
can you please attach show version
02-04-2019 10:14 PM
Are you trying to access via HTTP or HTTPS? Try https://<mangement_ip_address>
The management address must be accessible via the wired network to work can you ping the management IP address?
Are you just getting page can not be found? Can you SSH the management IP address?
Make sure you have followed all the pre-requisites steps in the deployment guide:
02-07-2019 09:45 AM
02-08-2019 09:10 AM
If you are using HTTPS to access the controller, you need to enter the following CLI command:
"config network secureweb enable"
This command allows users to access the controller GUI using “https://ip-address.” The default value is enabled. Secure web mode is a secure connection.
Enter "show network summary" and verify.
***Please rate all useful responses***
Jagan
