02-12-2019 05:58 AM - edited 07-05-2021 09:50 AM
Is it possible to schedule availability of WLAN for certain hours of the day? Do you only disable SSID broadcast or entirely disable WLAN itself?
I am running version 8.5.140.0
Solved! Go to Solution.
02-12-2019 10:23 PM
Try upgrdae to 8.8.111.0 version then you will not need Cisoc Prime because in new version you will have a option of scheduling.
Check the screenshot:
Info: with 8.5.140 -- You need to use ACL or Cisoc prime to enable/disable it.
Dont forget to rate helpful posts
02-12-2019 11:43 AM
First off, SSID schedule requires Cisco Prime, as far as I can tell. If you have a Cisco Prime and if Mobility Express is integrated with it, then, I´d say it is possible. Otherwise, I´d say not.
-If I helped you somehow, please, rate it as useful.-
02-12-2019 12:29 PM
02-12-2019 02:02 PM
Totally agree with the two solutions above.
For the Prime option look at this: https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/213414-schedule-ssid-availability-on-cisco-wlcs.html
For the time based ACL look at this https://www.pei.com/2016/02/time-of-day-access-for-guest-ssid-on-a-cisco-wlc/
02-12-2019 10:23 PM
02-12-2019 11:16 PM
Nice! Great ideas guys. I'm going to try upgrading the version as suggested.
Thanks!
06-23-2019 12:36 AM
Please show the steps to configure the same
06-23-2019 09:55 PM
Please go through the deployment guide:
06-23-2019 10:38 PM
I was trying to configure SSID scheduling on Cisco 3504 WLAN controller version 8.8.120.0 but the shared deployment method is for mobility express Access points. If you can share the configuration for Cisco 3504 controller.
