Moving an AP from Cisco 5760 to 5520
linda12345
We have some APs that have been relocated from one controller to another.
The original controller was a Cisco 5760 (IOS 3.6.6.E) and now im trying to get it to register to a Cisco 5520 (AIREOS 8.2.166.0)
I cant get onto the AP but a debug from the controller shows:
*spamApTask3: Feb 10 13:29:12.993: [PA] 00:6b:f1:66:58:80 ApModel: AIR-CAP3702I-Z-K9
*spamApTask3: Feb 10 13:29:12.993: [PA] Could not find image version of bundled AP(apType: 36)!!!
*spamApTask3: Feb 10 13:29:12.993: [PA] Unable to get AP Bundled Version. Using Controller Version!!!
*spamApTask3: Feb 10 13:29:13.002: [PA] 00:6b:f1:66:58:80 ApModel: AIR-CAP3702I-Z-K9
*spamApTask3: Feb 10 13:29:13.002: [PA] Could not find image version of bundled AP(apType: 36)!!!
*spamApTask3: Feb 10 13:29:13.002: [PA] Unable to get AP Bundled Version. Using Controller Version!!!
*spamApTask3: Feb 10 13:29:23.212: [PA] Could not find image version of bundled AP(apType: 36)!!!
*spamApTask3: Feb 10 13:29:23.212: [PA] Unable to get AP Bundled Version. Using Controller Version!!!
*spamApTask3: Feb 10 13:29:24.306: [PA] 00:6b:f1:66:58:80 AP 00:6b:f1:66:58:80 has default credentials and so invalid to support Telnet
*spamApTask3: Feb 10 13:29:24.306: [PA] 00:6b:f1:66:58:80 AP 00:6b:f1:66:58:80 has default credentials and so invalid to support SSH
*spamApTask2: Feb 10 13:30:07.930: [PA] 00:62:ec:35:d3:c0 ApModel: AIR-CAP3702I-Z-K9
*spamApTask2: Feb 10 13:30:07.930: [PA] Could not find image version of bundled AP(apType: 36)!!!
(TEST-WLC1) >show ap join stats summary all
Number of APs.............................................. 534
Base Mac AP EthernetMac AP Name IP Address Status
00:62:ec:35:d3:c0 N A TEST-WAP16I 10.126.50.81 Not Joined
00:62:ec:75:f1:10 N A TEST-WAP16A 10.126.50.74 Not Joined
The Ethernet MAC comes up with N A
Any ideas?!
10 Replies 10
Hi @linda12345
 This log tells you the problem:
"Could not find image version of bundled AP"
Run the command "show ap bundle  all"
Example output:
(Cisco Controller) >show ap bundle all
Primary AP Image Size
ap1g1 12932
ap1g2 11948
ap1g3 13940
ap1g4 19476
ap3g1 9908
ap3g2 13680
ap3g3 18836
ap801 8348
ap802 9816
c1140 8796
c1520 7492
c1550 10816
c1570 11736
c602i 3864
version.info 4
Secondary AP Image Size
ap1g1 12932
ap1g2 11936
ap1g3 13932
ap1g4 19424
ap3g1 9896
ap3g2 13672
ap3g3 18836
ap801 8336
ap802 9816
c1140 8796
c1520 7524
c1550 10808
c1570 11728
c602i 3864
AP 3700i should be bundle ap3g2.
-If I helped you somehow, please, rate it as useful.-
@Flavio Miranda
Thankyou for your reply. I should have mentioned, i have 50 perfectly good 3702 APs registered (came new in box) its just the ones that came from another location im having issues with.
show ap bundle all
ap1g1 12932
ap1g2 11948
ap1g3 13940
ap1g4 19476
ap3g1 9908
ap3g2 13680
ap3g3 18836
ap801 8348
ap802 9816
c1140 8796
c1520 7492
c1550 10816
c1570 11736
c602i 3864
version.info 4
--More-- or (q)uit
ap1g1 12572
ap1g2 11696
ap1g3 13580
ap1g4 14792
ap3g1 9696
ap3g2 13452
ap3g3 0
ap801 7984
ap802 9468
c1140 8588
c1520 7304
c1550 9636
c1570 11656
c602i 3864
version.info 4
Hi @Flavio Miranda
Thankyou for your reply. Sorry i should have mentioned I have already quite a few 3702s registered (they came brand new in box) only having issues with the ones that came from another site (and was registered to a 5760 controller. Are there issues moving an AP from an IOS controller to an AIREOS controller?!
show ap bundle all
ap1g1 12932
ap1g2 11948
ap1g3 13940
ap1g4 19476
ap3g1 9908
ap3g2 13680
ap3g3 18836
ap801 8348
ap802 9816
c1140 8796
c1520 7492
c1550 10816
c1570 11736
c602i 3864
version.info 4
--More-- or (q)uit
ap1g1 12572
ap1g2 11696
ap1g3 13580
ap1g4 14792
ap3g1 9696
ap3g2 13452
ap3g3 0
ap801 7984
ap802 9468
c1140 8588
c1520 7304
c1550 9636
c1570 11656
c602i 3864
version.info 4
There should be no issues to move them, the question is, what is your wan link between your site the AP’s are at and the 5520?  Since your 5520 has the right code, that shouldn’t be an issue.
Typically you just change the AP high availability and then bounce the AP. If there is something corrupted, then if you are remote, you would have to ssh to each AP and then delete the image file and private-config, tftp the recovery image and use option 43 or dns to point the AP to the 5520.
-Scott
Thanks @Scott Fella
The 5520 and these APs are all on the same lan. Unfortunately i cant SSH onto any of these. Looks like i'll have to rip them out of the ceiling and console onto them.
Linda,
I think you can enable ssh to the AP’s from the 5760. By default, ssh is disabled.
-Scott
Thanks @Scott Fella
Thats a good point. Will definitely enable SSH on existing APs. My next project is to swap out existing onsite 5760 controllers with 5520s. I'd hate to have this problem when dealing with hundreds of APs.
Scott,
what was this part:
Was the 5520 rejecting the link from the ios ap's due to cisco/cisco?
Linda, pick an ap and change the credentials to match those in the WLC...
migrating from WLC 5760 (IOS XE) to WLC 5520. Existing WLC (5760) is already integrated with Cisco ISE and Prime. Currently Access Points and WLC are in same vlan and WLC is discovered using local broadcast. While migrating  AP from OLD WLC to New WLC, what would be the best practice to be followed. suggestions on the below steps.
1. Install new WLC (5520) with new MGMT IP
2. Configure HA
3. Upgrade New WLC to 8.3.133.0
4. Integrate with ISE, Prime
5. Configure WLAN
6. Migrate AP to New WLC
7. Test and Monitor
You can go this way. I personally would integrate the new WLC after you have done the whole configuration. This is because I don't like Prime for configuration management.
Once the configuration is done, add the new WLC to the same Mobility Group.
After this, start by changing the primary WLC on an AP configuration in the Prime, this will cause the AP to immediately switch the WLC, reboot, update firmware, reboot, connect with new WLC. Then you can test your configuration and check if everything is working. Do this for the first 1-5 APs. Once you're confident everything is working, start to migrate them by floor or building, until you're done.
That's at least how I would do it ;)
Oh and don't forget to apply best practices from here, before changing the first AP:
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1250-series/design_guide_c07-693245.html (beginning at chapter "Wireless LAN Controller and Feature Specific Configuration Recommendations")
sbhadrav@cisco.com
Thankyou for your detailed response. That's a great strategy that will allow us to test before migrating all APs over but also to stagger the AP registration and d/l of the new firmware.
Thankyou for sharing. No doubt this will be helpful for others also!
