12-18-2006 08:31 AM - edited 07-03-2021 01:23 PM
Here is my configuration
1130 AP, WLSE Express (radius)
authentication : PEAP with ms-chapv2
My user database is on the WLSE.
MS-Peap works fine with my intel pro/wireless client but always failed with the integrated WZC client on XP SP2. I already patch it with KB885453 but this doesn't help.
Is there some specials parameters on the radius to make it works with WZC ?
Thanks for your help
12-18-2006 08:58 AM
review your log files, you may not have the client configured correctly... Possibly set the wrong certificate.
03-15-2007 02:42 PM
Untick the option to verify certificate in the windows config. PEAP is server side, client can ignore it. Also, check if you are trying to use windows initial login - if so, machine authentication must be enabled.
Hope that helps.
07-13-2007 01:33 AM
I have the same problem with the integrated WZC client on XP SP2. The intel pro/wireless client works fine. You have know any solutions?
07-13-2007 05:00 AM
Yes I found the solution.
WZC is not CCX compatible so you have to disable or make optional cckm on the APs with this command :
authen key-manage cckm optional
Bye
07-17-2007 11:20 AM
